It is currently Thu May 24, 2012 8:59 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 42 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Help required
PostPosted: Sun Jan 22, 2012 4:32 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
In that case you must have an air lock.
If the washing machine is hot and cold, you could try linking the hose between the two, then turn them on with the hot bath tap open.
PostPosted: Sun Jan 22, 2012 4:33 pm
Has thanked: 2 times
Yeah its just one of the modern machines with cold only, dont have a bath just an electric walk in shower.
PostPosted: Sun Jan 22, 2012 4:36 pm
OAP
You'll need to find a way to force the air out in that case.
PostPosted: Sun Jan 22, 2012 4:41 pm
Yeah ive done the hand over the kitchen water tap at full pressure with the hot tap on full, ive done this so far 60+ times and it doesnt seem to be shifting at all. Cant really do the hose thingy as the kitchen is a mixer tap and the bathroom is two individual taps.
PostPosted: Sun Jan 22, 2012 4:49 pm
OAP
Taps should have check valves so it's not always possible to do what you are trying, if you have isolating valves you may have to link from there.
If you have a wet vac that can work sometimes.
PostPosted: Sun Jan 22, 2012 4:54 pm
Well our plumber is going to call in the morning and will hopefully sort it out, just unsure if we should turn the central heating on.
PostPosted: Sun Jan 22, 2012 4:56 pm
Has thanked: 76 times
Been thanked: 372 times
If there is an airlock it could be in the pipe that runs between the cistern and the cylinder in which case backfeeding won't make much difference unless you get someone to put their hand over the end of the ventpipe in the loft :wink:
PostPosted: Sun Jan 22, 2012 5:09 pm
OAP
In that case you could put a hose on the cold feed as though you were draining the storage tank/cylinder.
May be an idea to try it anyway.
PostPosted: Sun Jan 22, 2012 5:16 pm
Ill just leave it for the professional tomorrow, he has all the proper kit.
Central heating wise, best to keep it or turn it on?
PostPosted: Sun Jan 22, 2012 5:55 pm
OAP
Should be ok to use the heating
PostPosted: Sun Jan 22, 2012 6:00 pm
That'll be a wet vac on the tap :wink:
Heating should be fine
PostPosted: Sun Jan 22, 2012 7:30 pm
Has thanked: 4 times
Been thanked: 39 times
I see you've been getting good advice. No pics though. Never mind hope all goes well tomorrow with the plumber. Let us know what happens. :huray:
Your problem is now our problem
