-> Electric Forum UK |
| Author |
Message |
damianfitch Junior Member
Posted: Sun Nov 09, 2008 5:31 pm Post subject: help required please !!! |
hi all,
i have the old type fuse box, a bulb has blown upstairs and knocked a fuse out, fuse wire has been replaced but not all lights are working now , any help would be appreciated
cheers
Damian |
| Back to top |
IDontBelieveIt Approved Electrician
Joined: 29 Jul 2008 Posts: 1193 Location: North Hampshire
Posted: Sun Nov 09, 2008 5:54 pm Post subject: |
THe lamp that caused the fuse to blow needs replacing. If still in circuit it may have caused the fuse to blow again. _________________ Never lie - that way you don't have to remember what you said. |
| Back to top |
robbie Junior Member
Posted: Sun Nov 09, 2008 10:20 pm Post subject: |
it could also be perhaps a fault developed in the wiring itself which caused the bulb and a joint somewhere to go.... this could explain why some of the lights are now working
If you are not experienced in the electric department then I would recommend getting in a sparks if the simple things dont work for you  |
| Back to top |
