It is currently Mon Oct 22, 2018 8:58 am
PostPosted: Mon Nov 06, 2017 11:37 pm
Hi all.
I currently have a battery powered Honeywell programmer/thermostat mounted on the wall.
I want to replace it with a British Gas WR1( rebadged Drayton Digistat receiver)
The current unit just has two wires as it’s just a switch basically (there was originally an analogue dial thermostat in place), so I presume these go to “common” and “call for heat” on the WR1?
There are also connections for permanent 230v live and neutral on the WR1. Can I take these from anywhere (with a 3A fuse), there’s no reason they have to come from the boiler?
Thanks in adavance.
PostPosted: Wed Nov 15, 2017 12:13 pm
Has thanked: 64 times
Been thanked: 543 times
If the contacts are volt free yes, if not then no. Two wires may be simple on/off but also could be connected to buss one has to be careful with general answers in case it is not simple on/off.
PostPosted: Wed Nov 15, 2017 8:47 pm
Thanks for the reply. Took the leap and did it anyway.
I kind of knew they were low voltage because I saw the plumber shorting them to turn the boiler on when he installed the controller.
Took a feed from the boiler switch to get mains voltage.
Receiver all worked fine, but after all the fuss the thermostat unit was faulty.
