It is currently Thu May 24, 2012 8:56 am
 Post subject: Help Please
PostPosted: Sat Nov 19, 2011 11:29 pm
Been thanked: 3 times
Right, after help again.
Just bought a small vanity unit and sink for a cloakroom. I've got plastic pipe going to the general area for both hot and cold. The tap is a mixer with 2 copper tails. How do I fix between plastic and copper. I assume I need isolation valve and I suspect I need flexible hoses to get angle from behind the blackboard of the vanity unit to the tails which will sit directly above the main area of the vanity unit.
Advice appreciated.
 Post subject: Re: Help Please
PostPosted: Sun Nov 20, 2011 12:13 am
OAP
Has thanked: 187 times
Been thanked: 2113 times
You can use push fit on copper or plastic.
If you use plastic you shouldn't need the flexi.
PostPosted: Mon Nov 21, 2011 9:21 pm
Has thanked: 17 times
Been thanked: 58 times
As above - or bin the copper tails and fit speedfit tails then pop 'em onto your plastic pipe (just don't forget the inserts!)
If at first you don't succeed - remove all evidence that you tried.
