It is currently Wed Jan 17, 2018 1:23 pm
Visit Thermo worx
PostPosted: Fri Nov 10, 2017 6:54 pm
Has thanked: 4 times
Been thanked: 1 times
Hi , wondering if someone can help? Wall was previously wallpapered so stripped it sanded wall and cleaned it down.i applied some emulsion watered down slightly and went all bubbly like. So have it a quick sand to get rid of it and just have it another coat and it has done the same , never had this before
PostPosted: Fri Nov 10, 2017 7:04 pm
Has thanked: 154 times
Been thanked: 93 times
Looks like old wallpaper paste. Did you sugar soap before painting?
PostPosted: Fri Nov 10, 2017 7:14 pm
No I didn't, would sanding it not have got rid of it all. It got a good sand
PostPosted: Fri Nov 10, 2017 7:19 pm
Has thanked: 1357 times
Been thanked: 3505 times
Old wallpaper paste can be a real pig to get rid of.
Wash down with sugar soap and hot water (as hot as you can stand) and scrape off anything that comes to the surface. Rinse and Repeat.
repeat as many times as necessary to get rid of all paste residue.
Alternative take the easier route... give it a coat of Zinsser Gardz. more expensive than elbow grease buuutt aa real time saver.
PostPosted: Fri Nov 10, 2017 7:27 pm
I might give the sugar soap a try first, would I have to take of the paint I have put on or will it work ok just sugar soap over the paint thanks
PostPosted: Fri Nov 10, 2017 7:35 pm
I thought sanding it would have got rid of all old paste?
PostPosted: Fri Nov 10, 2017 7:37 pm
Has thanked: 584 times
Been thanked: 680 times
Just get it well wet ... large sponge + water sprayer or similar. As you are wetting the surface and you move along, keep the starting point wet. Once you got it soaking for 15-30 minutes scrape to remove paint and paste residue ... if it has paste left it will feel slimy/slippery to you finger tips. When it is not slippery any more, rinse it using lots of clean water.
Scotchbrite pads can be very handy for rubbing it clean.
Yes, perhaps, maybe ... but looking at the photo(s) you posted [are they both the same] there are layers of paint or paste there that your sanding has not touched.
EDIT. Do you have any photos of the bubbling paint?
PostPosted: Fri Nov 10, 2017 8:09 pm
Sorry never realised they were the same. I've got another but again not to clear
For this message the author gordy has received gratitude : OchAye
PostPosted: Fri Nov 10, 2017 8:59 pm
Wall paper paste ... elbow grease is the order of the day. Even if you were to use Gartz as suggested by wine~o you would still need to put a lot of work into turning that in a smooth surface. Hot water, sugar soap and do not skimp on the effort needed.
For this message the author OchAye has received gratitude : gordy
PostPosted: Fri Nov 10, 2017 9:10 pm
Thanks. Will give it a go over the weekend
