www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
-> Central Heating & Boilers |
| Author |
Message |
ali Senior Member
Posted: Thu Dec 06, 2007 8:52 pm Post subject: Help me understand radiator valves please. |
I know that a thermostatic radiator valve means that the radiator will come on if the temperature drops to the level selected by the number you choose on the valve..........but does an ordinary valve mean the radiator is either on or off, and the heat will just be however hot the boiler is set to output?
Is that right?
I need angled valves for the stainless steel radiator I bought but don't know what to buy. |
| Back to top |
jason123 Senior Member
Joined: 16 Dec 2006 Posts: 1239 Location: Stellaville
Posted: Thu Dec 06, 2007 10:12 pm Post subject: |
HH is your man for this, you are correct with the TRV, as its a SS rad I presume its going in the bathroom, I think normally the bathroom rad is fitted with standard valves which help the boilers bypass function, you could fit a trv and the boiler bypass would work of course, just nobody ever complains of a bathroom being too hot so no trv. Standard valves are throttled back when trying to balance the whole system, leave the standards in the bathroom fully open, and slap anyone putting a towel on it.
Standard valves when fully open are on when CH is running yes. _________________ Stella Stella Stella oy oy oy |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
Posted: Thu Dec 06, 2007 10:53 pm Post subject: |
Jason is right... But you would need to balance the "by-pass" rad along with rest of system. _________________ www.hintonheating.com
| Back to top |
ali Senior Member
Posted: Fri Dec 07, 2007 5:52 pm Post subject: |
Thanks for helping.  |
| Back to top |
