It is currently Wed Feb 20, 2019 3:20 am
PostPosted: Tue Jan 30, 2018 10:18 am
Has thanked: 20 times
Been thanked: 1 times
I need a new cooker, I have decided on gas as I like the gas hobs and I believe it is like 10x cheaper to run gas than electric.
I can put in 50, 55 or 60 cm cooker.
Is the build quality better on the 55 or 60cm cookers?
There is not much choice at 50cm range, apart from a hotpoint ultima - are these any good?
PostPosted: Tue Jan 30, 2018 10:34 am
Has thanked: 643 times
Been thanked: 1815 times
They are all simple technology an insulated steel box, a burner with a flame failure device and a thermostat. The hobs are basic with a spark ignition and the grills are sometimes a double oven feature. Read the reviews carefully as loads are continental built cheap sh*t.
Painting with BIN
PostPosted: Tue Jan 30, 2018 5:42 pm
Has thanked: 1531 times
Been thanked: 3852 times
Build quality is nothing to do with size, some manufacturers are better than others.
Go for 600mm if you have the space as it makes the hob less crowded and you can get a bigger joint/nut roast in the oven. Have a look at leisure cp (google) for some well made cheapish ovens.
PostPosted: Fri Mar 09, 2018 4:01 pm
I ended up getting a Hotpoint 60cm with dual oven and it is amazing, sooo much better than the old one and I am cooking a lot more now.
PostPosted: Fri Mar 09, 2018 4:21 pm
Thanks for the update. I am glad you like your new oven :thumbright:
Painting with BIN
PostPosted: Fri Mar 09, 2018 4:46 pm
Has thanked: 701 times
Been thanked: 2027 times
i would say gas per kw is around 1/3to 1/4 the cost off electric
advantages
instant on and off so no time lag far cheaper than electric
disadvantages
naked flame flame creep round pans more expensive to buy more moisture produce when burning gas
if you have a gas cooker point its a no brainer :lol:
PostPosted: Fri Mar 09, 2018 4:49 pm
Has thanked: 61 times
Been thanked: 648 times
I have never been happy with our Hotpoint gas cooker the oven is the equivalent to 2 gas mark low (the main gas reg has been changed and it has been re-jetted with no change)
imho food cooks better with gas as it doesn't suck the moisture out of things like electric does YMMV
60cm gives you loads of options, 50cm limits your options greatly, it all depends on you budget £150 to way over £2k
PostPosted: Fri Mar 09, 2018 4:51 pm
According to the maths I did, it is actually 10x more expensive to cook with electric.
That's using the official figures of consumption according to ao.com for a typical gas and typical electric cooker, then the unit costs of gas & elec on my tarriff.
As you say, it is also much more convenient to cook with gas, and doesnt dry out food as much.
I had to cut my worktops a bit to fit the 60cm but now it fits perfect and was only a 60 min job. Cooker was 330 quid, the dual cooker is great too as you can use the small top oven for small jobs and you can also put plates in there to warm while using main oven. And for a roast it is perfect to roast in main oven, then move the roast into the top small oven (off) to rest it while cooking yorkshires/roasties in main oven.
PostPosted: Fri Mar 09, 2018 5:21 pm
I had to look up YMMV, just as well I did.
Electric doesn't "suck" anything out of anything. Regards electric vs. gas cooking, electric oven every time, Gas hob over standard electric hob buuuuttt Induction hobs are better than anything (though expensive to buy)
PostPosted: Fri Mar 09, 2018 5:53 pm
lol it dries things out as the air is more arid - its what you use to I suppose I learnt cooking on gas, I did the first year of a cookery course (NVQ iirc) but decided it wasn't for me, that was all on gas
PostPosted: Fri Mar 09, 2018 6:17 pm
simply cannot be 10 times more efficient you may get small variations for example you may be able to boil a cup off water ten times cheaper because there is no heat lag
but the average cycle over normal cooking routine will be little different to the direct ration off 3 or 4 to 1
you may possibly get up to 25% more use per kw because the heat is more direct but cant see it being much more :dunno:
any way still worth having :lol:
PostPosted: Fri Mar 09, 2018 6:40 pm
A lot of cooking involves "drying out" you wouldn't want your bread coming out of the oven as wet as it went in ? Same for cakes.
Casseroles have a lid on so any moisture coming off will condense back into the dish...
BTW have you seen the size of my Yorkshire puddings ?? :lol:
And no that isn't a miniature kettle. :mrgreen:
For this message the author wine~o has received gratitude : OchAye
