-> Electric Forum UK |
| Author |
Message |
Parentstoolbox Junior Member
Posted: Fri Apr 20, 2007 10:44 am Post subject: Help for a new boy |
Hello all
I have a problem with some spotlights in a room at home
When I switch on the lights, the lights may or not come on
If the light switch is left in the on position the spotlights will sometimes come on and go off again with no help from me
Im thinking it may be the transformer, If it is, How can I check and If I have to buy a new one, how do I know which one to get as it was probably supplied with the lights
Can this be dangerous?
This is a new house of mine and these lights were not fitted by me
Any help will be good with this
Julian |
| Back to top |
Rich-Ando Approved Electrician
Joined: 24 Mar 2007 Posts: 2618 Location: Derby, Derbyshire
Posted: Fri Apr 20, 2007 11:59 am Post subject: |
are they individual spot lights banked off a transformer?
is there more than one transformer?
is it a track light fitting with spot lights on?
is the transformer accessible?
can you test the output of the switch?
we need more information m8. |
| Back to top |
Posted: Fri Apr 20, 2007 12:54 pm Post subject: |
Hum,,,,
All I know right now is that the spots are not on a track
I will need to jump into the loft to look for the other bits
Will post the info over the weekend
Julian |
| Back to top |
baldelectrician Junior Member
Posted: Fri Apr 20, 2007 10:03 pm Post subject: |
Do you have a dimmer switch?
If so take it out of circuit. |
| Back to top |
