It is currently Thu May 24, 2012 8:44 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Sun Nov 20, 2011 10:06 pm
Has thanked: 1 times
Been thanked: 1 times
I have bought new doors to fit to the front of my kitchen however the hinges are in a different place :dunno:
This isnt a problem to fit to the doors but I probably need to be very accurate fitting the brackets to the carcase as it seems there is only a small adjustment on each one
Any advice to get them all in the same place?
PostPosted: Sun Nov 20, 2011 10:24 pm
Has thanked: 7 times
Been thanked: 17 times
Check inside the carcases there might be alternative fixing holes above and below the old hinge plates, there is on mine
Trevor
PostPosted: Sun Nov 20, 2011 10:29 pm
Unfortunately this is not the case on mine so i have to drill new holes but there is only a small adjustment up and down on the carcase plate which is why im concerned
PostPosted: Mon Nov 21, 2011 6:34 pm
Been thanked: 66 times
see if you can buy an off cut of hardboard to make up a template to help keep them all the same.
PostPosted: Mon Nov 21, 2011 6:57 pm
Has thanked: 134 times
Been thanked: 468 times
get yourself a bit off mdf/ply hardboard 2 mm smaller than the inside off a carcase height and 2" wider than the holes
a baton off 12x12to 15x15mm nailed to one edge off the board brill holes in correct points for the hinges along its length
alternatively as above but only from the inside top edge off the cupboard to the hinge center then double that then baton as above
you now have a jig for individual hinges by simply sliding to the top or bottom
PostPosted: Wed Nov 23, 2011 11:06 pm
As it happens it turned out to be an easier job than anticipated.
I had to remove 1 screw from bracket in carcase and loosen the other then turn it 180 degrees then re-drill and hey presto did this on both brackets,
probably got lucky but doors look great :huray:
For this message the author fabiavRS has received gratitude : big-all
PostPosted: Thu Nov 24, 2011 12:21 am
thanks for getting back to us the feedback makes it all worthwhile cheers :thumbright: :thumbright:
Users browsing this forum: No registered users and 6 guests
