It is currently Thu May 24, 2018 3:30 am
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Help advise required
PostPosted: Fri Apr 21, 2017 4:27 pm
Hi I have an outside halogen flood light wired into a 13 amp plug in the garage, and blow to bulbs would you be kind enough to advise if this is wired correctly
I.e. Live from plug wired to live in lamp
And negative to negative
 Post subject: Re: Help advise required
PostPosted: Fri Apr 21, 2017 4:50 pm
Has thanked: 1421 times
Been thanked: 3659 times
:welcomeuhm:
Yes live to live and neutral to neutral is correct; If I understand your post correctly every time you replace the bulb it "Blows".
There could be a few reasons for this including a faulty light fitting.
Is this an old fitting that has recently started blowing bulbs ? or new wiring ?? what happens if you plug say a table lamp into the same socket ?
PostPosted: Fri Apr 21, 2017 5:48 pm
Has thanked: 11 times
Been thanked: 56 times
One factor to remember about halogen lamps is never to handle them with bare hands and keep the replacement clean and free of dirt and grease when fitting.
For this message the author Morbius has received gratitude : AAA.Handy.Man
PostPosted: Fri Apr 21, 2017 5:59 pm
Has thanked: 505 times
Been thanked: 98 times
:thumbright:
It's so easy to forget the NOT handling with bare hands when attempting to fit those bulbs into their spring-loaded slots. :thumbleft:
PostPosted: Fri Apr 21, 2017 6:21 pm
Agreed but..... that wouldn't cause the bulbs to blow straightaway; it would reduce the bulb life though.
PostPosted: Fri Apr 21, 2017 6:33 pm
To be honest we're both grasping at straws a bit in trying to help, given that the op was a bit vague with their question.
For this message the author Morbius has received gratitude : wine~o
PostPosted: Fri Apr 21, 2017 6:47 pm
Has thanked: 332 times
Been thanked: 1731 times
Cheap bulbs are a significant factor.
Loose connections are another. If this is a 'tube' type bulb then it should be held FIRMLY between the contacts.
For this message the author kellys_eye has received gratitude : wine~o
PostPosted: Fri Apr 21, 2017 6:53 pm
Without more info we are " like the blind man,
in a dark room,
looking for a black cat
that isn't there..."
For this message the author wine~o has received gratitude : Morbius
PostPosted: Fri Apr 21, 2017 7:26 pm
So turn the light on then!
PostPosted: Fri Apr 21, 2017 7:27 pm
But the bulb blows........ :scratch:
PostPosted: Fri Apr 21, 2017 9:10 pm
Or does it?. :wink:
PostPosted: Fri Apr 21, 2017 9:17 pm
Depends on if the cat is still alive or not...... :mrgreen:
PostPosted: Sat Apr 22, 2017 7:14 pm
There was no cat ?? Or was there??? Where is AAA when you need him ???????
PostPosted: Sun Apr 23, 2017 7:52 am
Approved Electrician
Has thanked: 161 times
Been thanked: 558 times
Where is Schrödinger's cat when you need it?
PostPosted: Sun Apr 23, 2017 8:06 am
Has thanked: 64 times
Been thanked: 537 times
My wife bought a Aldi flood lamp with a R7s 120W quartz tube, it lasted a couple of days, now fitted with a LED replacement 5W which is ample, also had problems with water in the fitting and had to drill a drain hole in the PIR it now works great onto second year.
Mothers house I bought a 10W Screwfix flood lamp LED built in works great. Although too sensitive so a little black tape on the sensor.
