Ultimate Handyman Home
Heating Will Not Work But Hot Water Does, Please Help..
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
wokeye
Junior Member
PostPosted: Sat Oct 04, 2008 12:42 pm    Post subject: Heating Will Not Work But Hot Water Does, Please Help.. Add User to Ignore List Reply with quote
I have a pretty old heating system that I want to get replaced affter this winter, but would like to try and repair it if at all possible. The system is a Thorn EMI back boiler, hot water cylinder upstairs a header tank in the loft, and a 3 way honeywell motorised divertor valve. The water is working fine. However when I select heating the boiler starts but the I am getting no heating. I have looked at the way valve and pump which is located underneath the hot water cylinder. The valve is not opening at all when heating selected on the timer/programmer. The pump also does not seem to be running, as I thought I might have felt some vibration or something from it ? I replaced the syncron motor on the valve last year for a similar fault. Unfortunately it is an old motorised valve so I cannot replace the valve head without breaking the line, so a new valve will be required. Anybody any ideas, is it probably the valve? Just thought that I would be able to tell that the pump is running and I can't. I have tried a spare room thermostat and this has done nothing, although the boiler is running anyway. Thanks for any advice.
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 1:12 pm    Post subject: Add User to Ignore List Reply with quote
Sounds likely to be be the valve
Scruff
Back to top
wokeye
Junior Member
PostPosted: Sat Oct 04, 2008 3:49 pm    Post subject: Add User to Ignore List Reply with quote
I am sure that this is an electrical problem. I was messing about trying a spare old thermostat that I had and the heating came on for a while, i.e the valve opened and I could tell the pump was running. I then switched the electric off again to refit the thermostat into it's housing and it would not work after this. Is there a way to link the thermostat out by any chance? If so which wires would I link together. It has a red, blue and yellow wires connected to different points. I am assuming that thermostat not only starts the boiler but operates the valve and pump, it would appear this way anyway. Please help.
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 4:16 pm    Post subject: Add User to Ignore List Reply with quote
Give me some makes and models on the stat and valve.
Have you got a multi-meter
Scruff
Back to top
wokeye
Junior Member
PostPosted: Sat Oct 04, 2008 4:29 pm    Post subject: Add User to Ignore List Reply with quote
Thanks mate. The valve is a Honeywell Sundial Y Plan 3 position divertor valve it also had this number on it V4073AI039. The stat is an old Honeywell T6160B or its longer number T6160B1004. I have also had trouble with programmers in the past but this was just the boiler not starting that is a Honeywell ST699. I do not have a multimeter but can get one off my brother. Thanks very much for the help it's very much appreciated.
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 4:48 pm    Post subject: Add User to Ignore List Reply with quote
Link 1-3 in the room stat should activate the MV, provided the programmer is calling for htg
Scruff
Back to top
wokeye
Junior Member
PostPosted: Sat Oct 04, 2008 4:53 pm    Post subject: Add User to Ignore List Reply with quote
Cheers Scruff I will give that a try and let you know how I get on. Thanks again Thumbright
Back to top
wokeye
Junior Member
PostPosted: Sat Oct 04, 2008 5:24 pm    Post subject: Add User to Ignore List Reply with quote
Thanks for the help Scruff tried that but still no luck. I might have to get somebody out to check it out as I have not got a clue. Could it be the programmer at all?
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 7:07 pm    Post subject: Add User to Ignore List Reply with quote
This is why you need the multi-meter to check the wires out, starting with the programmer.
With the programmer calling for heat there should be power on terminal 1 in the room stat, simple to check, and at the same time confirms any doubt about the programmer
Scruff
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 7:18 pm    Post subject: Add User to Ignore List Reply with quote
Once you have power on terminal 1 room stat, it switches terminal 3, which in turn puts power on the white wire in the zone valve
No Power to Valve - Hot Water Only (Port B Only)
240 V on White Wire - Hot Water & Heating (Port A & B)
240 V on White & Grey Wire - Heating Only (Port A Only)
240 V on Grey Wire only - Valve is held in last port of call
Scruff
Back to top
wokeye
Junior Member
PostPosted: Sat Oct 04, 2008 7:40 pm    Post subject: Add User to Ignore List Reply with quote
Thanks Scruff I will need to get a multi-meter. The stat is wired as follows I hope this is correct. Red wire - 1, Blue - 2, Yellow - 4. I am not that sure what you mean about the wires to the valve. Thanks for the great advice very much appreciated Thumbright
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 7:53 pm    Post subject: Add User to Ignore List Reply with quote
But the yellow should be on terminal 3 ?????????
Scruff
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
