It is currently Sun Mar 24, 2019 3:03 am
PostPosted: Sat Aug 04, 2018 11:52 pm
Hi Guys!
First post and the reason why I made an account.
Currently planning a DIY project for the summer house. I'd like to house lights in compartments in the three corners of the room and put a panel with a cut out pattern over them.
The plan currently is to get the following panel LED lights https://www.beamled.com/biard-40w-panel-light-300-x-1200mm-led.html then bracket them on a chipboard panel, attached to each wall with 135 degree brackets and then add magnetic catches above and below the light so the "pattern panel" can be removed for easy access. There will be a 190mm gap between the corner of the wall and the chipboard minimum.
I'm here because these lights are intended as ceiling lights and I'm concerned that the heat sink at the base of the LED won't have enough air flow. Do you think that's a valid concern? How could I remedy this?
PS For anyone interested, this is the pattern I'm using
And this is the desired effect
PostPosted: Sun Aug 05, 2018 12:00 am
Has thanked: 706 times
Been thanked: 2037 times
before you go ahead i would suggest thats a massive amount off light
what size is the room ???
PostPosted: Sun Aug 05, 2018 12:03 am
It's about 4.5m by 4.5 meters.
I went for it as I was struggling to get uniform light distribution of a significant length and width. You think halogen (the kind sold for under cabinets) might work better? It would save having to potentially rewire.
PostPosted: Sun Aug 05, 2018 12:08 am
you need well spaced out at the correct point
as in search lights at 3 corners wont give a good spread off light
possibly 3x3 evenly spread across room at perhaps 5w would give a better spread if down lighters
or 4x 5w if pendants would probably be more than enough
PostPosted: Sun Aug 05, 2018 1:49 am
Has thanked: 41 times
Been thanked: 1446 times
I guess it's too early in the morning (or too late at night) I can't see any mention of heatsink
Users browsing this forum: Google [Bot] and 1 guest
