It is currently Thu May 24, 2012 8:02 am
 Post subject: Headlights on the blink
PostPosted: Sat Jan 28, 2012 8:54 pm
Has thanked: 49 times
Been thanked: 4 times
I have a Ford Courier van. The headlights seem to have packed in without any warning. The side lights and full beam work fine but no main beam! I had to drive home in full beam with everyone flashing at me. I wish I had asign on the car saying............I know, I Fuc$ing know.
I can't imagine it's the bulbs, not with both going at the same time. Any ideas what the problem could be?
PostPosted: Sat Jan 28, 2012 8:56 pm
Has thanked: 166 times
Been thanked: 612 times
Fuse....
check the manual, you probably had one light blow (dipped beam) taking the fuse out..
Might need to change the faulty bulb and the fuse..
PostPosted: Sat Jan 28, 2012 9:17 pm
Has thanked: 6 times
Been thanked: 108 times
I had that on Vauxhall I had.
Both bulbs went, without knocking out the fuse.
I suppose one went, sudden current increase blew the other maybe.
Check fuse, check bulbs.... think they are H4s in Fiestas?
Remember not to touch the actual glass bulb itself with your fingers.
PostPosted: Sat Jan 28, 2012 10:04 pm
Has thanked: 62 times
Been thanked: 217 times
They usually work via a relay.
This post may contain nuts
PostPosted: Sat Jan 28, 2012 10:33 pm
Been thanked: 5 times
probaly just both bulbs blown
PostPosted: Sat Jan 28, 2012 11:29 pm
Okay I'll let you know tomorrow.
PostPosted: Sun Jan 29, 2012 5:38 pm
The fuses seem okay. I'll buy new bulbs tomorrow.
PostPosted: Wed Feb 29, 2012 4:18 pm
Might be the dip/full switch, as these sometimes burn, but rarely in a vehicle designed to use halogens. While you are at it make sure the headlights have a GOOD earth. As others have suggested might also be the relay, or feed to the coil.
Don't forget folks. Just a reminder NEVER touch the glass of Halogen bulbs when fitting.
