-> Plumbing Forum |
| Author |
Message |
TryAgain Junior Member
Posted: Tue Feb 27, 2007 2:05 pm Post subject: Header tank or mains |
The cold water from my upstairs taps comes from the header tank, toilet water comes from mains direct. Downstairs cold taps comes from mains. As I would like to use the upstairs water as a drinking supply can anyone help me to swap supplies to my upstairs cold taps, how do I identify which is which supply up in the loft?. I've done a bit of DiY plumbing with a new shower and rad in the BR and moving supplies in the kitchen  |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Tue Feb 27, 2007 3:51 pm Post subject: |
heeelllooo tryagain and welcome :grin: :grin: :grin: :grin:
assuming the cold mains travels up through the bathroom the feed to the cistern is more likely to "t" off on the way up
can you not follow the pipework and if you find a "t "going up and down it may be the cold mains passing through on the way up or indeed on the way down _________________ we are all ------------------still learning |
| Back to top |
Posted: Mon Mar 05, 2007 3:31 pm Post subject: |
Thanks for that Al
I have had a look in the loft and see what looks like the mains coming in because it goes straight into the central heating and water system header tanks via ball cock systems, it doesn't seem to 'T' off anywhere. On the way out of the botton of the cold water header tank are 2 pipes. One I think goes to the hot water tank as header pressure, the other I suspect goes into the bottom of the hot water tank to fill up from the bottom. Do you think that sounds sensible?
If I were to connect mains water to either of these pipes I recon I would pressurise the hot water tank with mains pressure and I am not sure if that is a good idea. What I really want to do is feed the cold tap system with fresh water. Any suggestions please?? _________________ Pete Steele |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
| Back to top |
Posted: Tue Mar 06, 2007 9:44 am Post subject: Header tank or mains |
Mr Hinton
Thanks for the reply and the graphic illustration, it would make a bit of a mess of Mrs TryAgain's sheets and towels in the airing cupboard
Any tips on how to trace the pipes I need to connect mains to my upstairs cold water system gratefully received. Thanks.
| Back to top |
Posted: Tue Mar 06, 2007 6:54 pm Post subject: |
the easiest way is to do this from the loft.
locate the main cold water storage tank.
The cold main is the one connected to the ball valve :grin:
There should be 2 outlet pipes at the bottom of the tank.
One is the cold to the taps, and the other feeds the cylinder.
The cold feed to the base of the cylinder is probably the easier one to find, this is the one to leave alone!
The other one is the cold feed to the taps. this will need cutting, cap the feed from the tank, than connect the end from the taps to the cold main. _________________ www.hintonheating.com
| Back to top |
Posted: Thu Mar 08, 2007 9:27 pm Post subject: |
Mr Hinton
Thanks again for your help. It seems straight forward so I will have a look - then call someone in!!! It will be a little while but I'll let you know how I get on.  |
| Back to top |
