Ultimate Handyman Home
Have I bled system incorrectly ?
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
AndyA
Junior Member
PostPosted: Sun Dec 02, 2007 11:53 am    Post subject: Have I bled system incorrectly ? Add User to Ignore List Reply with quote
Ref this thread.
http://www.ultimatehandyman.co.uk/forum1/ideal-elan-ii-kettling-and-banging-badly-t5881.html
When I refilled the system I turned the heating on before starting to bleed the radiators, should I have bled them cold at first, then turned heating on and re bled when warm ?
Back to top
AndyA
Junior Member
PostPosted: Sun Dec 02, 2007 11:55 am    Post subject: Add User to Ignore List Reply with quote
I'm wondering if I might have introduced air into the system ?
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sun Dec 02, 2007 11:58 am    Post subject: Add User to Ignore List Reply with quote
you should bled the rads when the timer is off, so pump is not in operation.
doesn;t matter if hot or cold.
www.hintonheating.com
Back to top
AndyA
Junior Member
PostPosted: Sun Dec 02, 2007 11:59 am    Post subject: Add User to Ignore List Reply with quote
Thanks Hinton, I think I'll empty and refill then bleed correctly this time. Bang Head
Back to top
Hoovie
Devon DIYer
PostPosted: Sun Dec 02, 2007 12:01 pm    Post subject: Add User to Ignore List Reply with quote
I'll add one comment - do it cold (or cooled down a bit) and you won't get scalding hot water coming out at you once the air is gone! Embarassed
Back to top
AndyA
Junior Member
PostPosted: Sun Dec 02, 2007 12:03 pm    Post subject: Add User to Ignore List Reply with quote
Thanks, I did try and bleed the rads a couple of days ago but they all seemed fine, it's just that sometimes I can hear vibration in one of the pipes that runs under one of the bedroom floorboards, I wondered if it might be air ?
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sun Dec 02, 2007 12:04 pm    Post subject: Add User to Ignore List Reply with quote
NO NO NO
dont keep emptying your system!
just turn it off and bleed it.. :grin:
Back to top
AndyA
Junior Member
PostPosted: Sun Dec 02, 2007 12:07 pm    Post subject: Add User to Ignore List Reply with quote
OK I'll let it cool down then try and bleed it again, I suspect that I won't get lucky and find air . . . but it's worth a go. :grin:
Thanks again for the advice. Thumbright
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sun Dec 02, 2007 12:11 pm    Post subject: Add User to Ignore List Reply with quote
as i said before, the more you drain it, the more limescale you add.
also it may take a while to settle after refilling..
Back to top
AndyA
Junior Member
PostPosted: Sun Dec 02, 2007 12:13 pm    Post subject: Add User to Ignore List Reply with quote
Got it, I hadn't considered that until you mentioned it. Thanks very much.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
