It is currently Thu May 24, 2012 7:49 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: Hard drive failed
PostPosted: Wed Jan 07, 2009 9:32 am
Has thanked: 10 times
Been thanked: 75 times
My laptops hard drive has popped it cloggs
Its a 2 year old sony vaio is there a download facility from sony to reinstall all the default software onto the new disk through a 3rd party computer.
James
 Post subject:
PostPosted: Wed Jan 07, 2009 1:47 pm
Pro Sparky
Has thanked: 85 times
Been thanked: 193 times
has it stopped completely or is it just clicking? does it spin perfectly but give you error messages on start?
if the drive still spins but clicks you can recover some of it. if it's just the directory thats screwed you can recover most of it.
when you say install the default software, do you mean the OS as in xp/vista?
 Post subject:
PostPosted: Wed Jan 07, 2009 4:34 pm
Has thanked: 3 times
Been thanked: 6 times
There are a couple of things you can attempt to recover from a faulty harddrive...if its the bearings going.
Leave the hardisk (laptop) in the fridge overnight. This will cool the compenants and hopefully give you 10-15minutes use before it warms up and starts sticking.
Otherwise gentle but firm taps (light knocks) from a rubber mallet can loose sticking drives and again give you a few minutes use.
Use the time to download the data/software you need before replacing teh drive.
Put your Laptop Model's details in there for the sony support
http://www.vaio-link.com/downloads/prei ... en_gb_cons
Don't buy a dwarf with learning difficulties,
It's not big and it's not clever.
 Post subject:
PostPosted: Wed Jan 07, 2009 4:55 pm
The drive is completely sh@gged I have a back up of the important stuff but the recovery disk has done a runner and of course you dont get windows disk and drivers anymore. The cost of a new drive and a copy of Vista or XP if I can get it makes repair nearly as much as a curries special.
 Post subject:
PostPosted: Wed Jan 07, 2009 5:03 pm
Sparky, you should have an Install key code on a label on the base of the laptop. You should only need to find the media, which could be purchased from an Ebay seller or a local PC shop (make sure you choose OEM media)
Then all you need is a copy of the network or modem (depending how you connect to broadband) card drivers for your laptop (as you're online now, download those to a USB or CD)
When you've installed Windows, install the card drivers then you should be able to download the rest of the software direct to the laptop.
HardDrisks aren't that expensive just check you get the right type, sata/ide
http://computers.shop.ebay.co.uk/items/ ... 913.c0.m24
Fitting could be tricky but just get a set of matchmakers screwdrivers for dismantling the case.
 Post subject:
PostPosted: Mon Jan 19, 2009 5:37 pm
If you have to cd key on the label stuck somewhere on the laptop then all you need is a copy of xp/vista on cd.
You can just get copy from a friend or someone if need be, there's no law against copying an windows cd.
 Post subject:
PostPosted: Tue Jan 20, 2009 10:37 am
Has thanked: 21 times
Been thanked: 27 times
the installation discs are worthless, its the keys that microsoft worry about.
thats why they dont bother wasting time copy protecting the cds but concern themselves with the keys
 Post subject:
PostPosted: Tue Jan 20, 2009 11:54 am
Been thanked: 69 times
Most hard drives have a 3 year manufacturers warranty. You have to go to their website and enter the serial number off the drive then they will authorise a return (by post at your expense). They will then repair or replace. Does not get your data back though. Used this service many times when I ran a computer business. It usually takes 2 to 4 weeks to get your replacement.
Mike
 Post subject:
PostPosted: Tue Jan 20, 2009 7:00 pm
Seagate was 5, now between 1 and 3 years
Samsung is either 1 or 3 years.
etc
Check the name on top of the drive, go to the manufacturer site, and request a replacement. Some come and collect, others ask for it to be sent in.
My pref is for Seagate drives and Hitachis, Not so keen on Fujitsus...OEM junk, loud and slow. Western Digitals can be loud and they are obsessed with this eco malarkey. Maxtor are rebadged budget seagates.
 Post subject:
PostPosted: Wed Mar 25, 2009 10:03 am
email me your address and will post a copy of the windows xp or vista and a recovery software for fat32 and ntfs if you still need it
Thanks For Yor Time
Time Lord
