It is currently Thu Jan 17, 2019 3:39 am
 Post subject: Handrail, how to attach
PostPosted: Fri Sep 14, 2018 12:55 pm
Has thanked: 755 times
Been thanked: 842 times
Hi, the photo shows a 75x75mm post on which I need to attach a handrail. (I will shorten the handrail a bit and round the end into a ball shape of some kind). It is possible I will create an extra support for the handrail in the middle of the length (current length around 1800mm).
My options seem to be:
1 - 2-3 crews from the top straight down to the post;
2 - use angle brackets that I can bend or unbend to match the existing angles
3 - use a strap flat, screw it on the post and screw the handrail from that (don't fancy recessing either wood for the strap).
Is there some other more obvious way that I am missing? :dunno:
PostPosted: Fri Sep 14, 2018 1:10 pm
Has thanked: 696 times
Been thanked: 2013 times
you could scew screw in the front and back off the posts
front off post start say 2" down and drill into the post at about 15 degrees to enter the handrail at about 45 degrees
at the back about 1" from the top
For this message the author big-all has received gratitude : OchAye
PostPosted: Fri Sep 14, 2018 1:33 pm
Has thanked: 1185 times
Been thanked: 1079 times
What about this type of thing
https://www.axminster.co.uk/zipbolt-str ... tor-504430
If you look on the site they do exterior grade ones as well
http://zipbolt.com.au/product-items/zip ... ix-17-150/
For this message the author Dave54 has received gratitude : OchAye
PostPosted: Fri Sep 14, 2018 2:00 pm
thinking about a centre support to look like a feature rather than just practical
perhaps a an "A" frame quite shallow from the bottom rail to under handrail made from say 2x1 or even 3x1 affixed to the bottom and middle rail inner face
the angle off the top half may have to be at a tighter angle to look fit in so a compromise between what looks symetrical and what is practical
PostPosted: Fri Sep 14, 2018 3:28 pm
Has thanked: 873 times
Been thanked: 377 times
:withstupid:
Those zipbolts may not be suitable for outside use. Plus maybe overkill for something that doesn't particularly have to be that decorative.
PostPosted: Fri Sep 14, 2018 4:43 pm
OK. I can see how I can screw from the post into the handrail. Would you opt for 2 screws at the back of the post and two at the front or just one each side? [Tempted to try with just 2 from the back only].
The post which is against the house is 75 wide but probably half the thickness but may not get as much water from rain so I might just screw top down . [If I work at it I will soon find a reason to buy longer than I have stainless screws].
Below are a couple of photos of the original. No A frame, just one piece of the same planks as used for the side runs, + another piece in between to get the vertical plank to reach the middle (width) of the handrail.
Kind of elegant because it is in proportion with the size of the rest of the wood. And I am back to how do I fix a 21-22mm thick plank onto the handrail :-( The original had everything nailed through the rail.
