It is currently Thu Dec 13, 2018 7:27 am
PostPosted: Wed Nov 08, 2017 2:05 pm
Has thanked: 2 times
Hi there. A plumber installed a Mira 'Silver' Exposed Thermostatic mixer in our house about 4/5 years ago. The temperasture is now all over the place and I need to get the thermostatic valve out but to do this I need to get a grub screw out which is situated through a small hole about 5mm diameter under the casing. I cannot remove the grubscrew that holds the control lever in place. The 2.5 mm allen key fits but wont turn. I gave tried WD40 and its soaked for a couple of weeks with added squirts. I have tried to tigjhten slightly before trying to undo and I have tapped it with a punch but it still wont budge. I cant get a screwdriver hex bit through the concealing hole as its too small a hole and the allen key has snapped on one occasion as its only a 2.5 mm key and not strong. Any suggestions for getting round this gratefully received.
PostPosted: Wed Nov 08, 2017 2:09 pm
UHM Super Moderator
Has thanked: 179 times
Been thanked: 617 times
I have deleted your other post. Please remember one thread per topic.
PostPosted: Wed Nov 08, 2017 2:57 pm
Has thanked: 1172 times
Been thanked: 1068 times
You can get longer bits. But those small allen headed grubscrews are a PIA.
Try a good quality allen key.
If the hole is rounded try tapping in a torx or similar bit that is just oversize.
Final thing is to drill out. Retap, fit larger grubscrew. Provided there is enough material there to do that of course.
I had one the other day in a door handle. :angryfire:
For this message the author Dave54 has received gratitude : Hopefamily1
PostPosted: Wed Nov 08, 2017 4:24 pm
Has thanked: 45 times
Been thanked: 713 times
It's probably rusted solid, you will round it out or break the key (as you have round) before it comes loose. Drill it out as mentioned above.
For this message the author Rorschach has received gratitude : Hopefamily1
PostPosted: Wed Nov 15, 2017 9:47 am
Thanks. I will try and get a more robust allen key then tap in a torx or similar if unsuccesful. drilling final strategy!
PostPosted: Tue Nov 21, 2017 9:49 pm
Mr. Grumpy
Has thanked: 31 times
Been thanked: 116 times
just had the same problem trying to take off a mixer tap handle. I drilled it out and managed to get the handle off (with a lot of huffing and puffing). Didn't need to retap as once the handle was off I could access it a lot easier
Be careful not to go to aggressive with the drill, I punch straight through the end into the soft plastic behind
Users browsing this forum: arco_iris and 0 guests
