It is currently Thu May 24, 2012 7:06 am
 Post subject: Gravity hot water
PostPosted: Mon Jul 20, 2009 3:57 pm
Has thanked: 2 times
Hi all first post, I have a quick question.
In a standard gravity setup with cold water tank in loft and hot water cylinder on first floor, is the 'head' the distance between the bottom of the cold water tank and the cylinder or the distance from the CWS to the outlets?
Its just our kitchen hot tap has much better force than the bathroom ones but I was under the impression the head was from the CWS to the HWSC.
Thanks for any replies. :-)
 Post subject:
PostPosted: Mon Jul 20, 2009 4:07 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
In the case of the hot water, neither, the head is either the bottom or half way up the storage tank, to the highest point in the pipework.
Depending on the pipe sizes you will get more volume at the lowest level, because the secondary head is greater on the ground floor than the 1st.
 Post subject:
PostPosted: Mon Jul 20, 2009 5:26 pm
Deceased 21-10-2011 R.I.P
Has thanked: 9 times
Been thanked: 93 times
There are two heads.
The static head is the pressure you get when you stuff your finger in the tap. That's the height of water between your finger and the water level in the cold water cistern.
The dynamic head is when the tap(s) are running. That will be the static head less the pressure drop in the pipes.
 Post subject:
PostPosted: Mon Jul 20, 2009 6:11 pm
Thanks for that I think I get it now. :lol:
Users browsing this forum: carder1 and 4 guests
