It is currently Thu May 24, 2012 7:06 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
PostPosted: Sun Jan 22, 2012 5:23 pm
Has thanked: 9 times
When I was a young lad I can remember running gravity flow and return pipes from a solid fuel boiler vertically into the roof space of a bungalow and then dropping to an indirect cylinder in the airing cupboard, I can remember that we used to vent both F &R but I have forgotten any other criteria for this to work.
This is purely to satisfy my own memory loss when thinking of the 'old days'
PostPosted: Sun Jan 22, 2012 5:40 pm
Has thanked: 76 times
Been thanked: 372 times
Our very own retired master plumber Scruff will be along later. He probably made his out of lead :lol:
For this message the author Razor has received gratitude : pipethreader
PostPosted: Sun Jan 22, 2012 6:02 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
As the flow rises it pushes the cold down giving you the circulation.
On the ladder system you will have several flows and one common return.
Quite often the vents would go through the roof and turn down over the tiles
For this message the author thescruff has received gratitude : pipethreader
PostPosted: Sun Jan 22, 2012 7:44 pm
Has thanked: 4 times
Been thanked: 39 times
Very simple system without pumps relying on hot water rising. Even though pumps have taken over that same circulation acts around our radiators and in hot water cylinders. Don't remember vent pipes going on roof tiles though! :dunno:
Your problem is now our problem
For this message the author moggridgeplumbing has received gratitude : pipethreader
PostPosted: Sun Jan 22, 2012 8:14 pm
Has thanked: 57 times
Been thanked: 99 times
Was quite common to have the old steel vents poking through the roof
Always used to do main flow and return in lead to take care of expansion, god knows how much that would cost now
Do not forget you have to have the heat loss to make above work ,so pipework and cylinder coil took this into account and was a lot bigger
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
For this message the author white pan man has received gratitude : pipethreader
PostPosted: Sun Jan 22, 2012 8:20 pm
OAP
Common practice on larger systems, to take the vent pipe through the roof.
The reason hot water rises is, it becomes less dense the hotter it gets.
PostPosted: Sun Jan 22, 2012 8:48 pm
That explains why I can do the newspaper crossword when on holiday and at home not a chance!! :-P
For this message the author white pan man has received thanks - 2: Argyll, pipethreader
PostPosted: Sun Jan 22, 2012 9:32 pm
I was joking about the primary's being in lead :shock:
Respect to you old plumbums :salute:
PostPosted: Sun Jan 22, 2012 9:53 pm
Doesn't work with Blondes! :lol: :lol:
PostPosted: Sun Jan 22, 2012 11:55 pm
Been thanked: 62 times
stratification mon!!!(say in a Caribbean accent)
For this message the author LordCross has received gratitude : pipethreader
PostPosted: Wed Jan 25, 2012 8:16 pm
Thankyou all for your welcome replies,.... pipethreader
Users browsing this forum: carder1 and 4 guests
