It is currently Thu May 24, 2012 7:04 am
PostPosted: Fri Dec 30, 2011 8:52 pm
Has thanked: 1 times
I have just done my gravel drive. It is 260 m2 and I used a 10-20 mm angular hard limestone.
It sits 50mm thick on a 8" sub base of mot type 1.
It has been vibrated and rollered and generally I am very happy with it, however as my drive is an in and out, where we turn we are starting to see ever so slight movement.
I did consider coregravel but due to the cost I figured I would save my £5000 and only spend £1000 on be gravel.
I don't regret no buying the core gravel stabiliser but am wondering if there is any way to firm up the gravel further to prevent future rutting?
I went out the other morning after a heavy frost and the drive way solid. This got me thinking that there must be a way to glue/bond the gravel so it doesn't move?
Could there be a resin spray that would glue or set the gravel in place???
Mark
PostPosted: Fri Dec 30, 2011 9:43 pm
Has thanked: 15 times
Been thanked: 160 times
I dont think you will find anything to glue the gravel together.
50mm is a bit deep for topping stones, if you had cut the depth down it might not have moved so much,best to rake it out level every now and then.
PostPosted: Fri Dec 30, 2011 10:42 pm
Has thanked: 7 times
Been thanked: 128 times
There are epoxy products available for laying/bonding gravel, I know nothing about them other than that they exist.
PostPosted: Fri Dec 30, 2011 11:54 pm
Can anybody point me in the direction of a good epoxy product for use on an existing driveway?
PostPosted: Sat Dec 31, 2011 8:59 am
Has thanked: 11 times
Been thanked: 116 times
Don't bother it's gonna be a lot more expensive than the stabiliser. It's called Resin Bonded. It's where the gravel is mixed with an epoxy and then laid.
Cheers,
Darren
Property Refurbishment & Maintenance Dorset
Users browsing this forum: darrenba and 25 guests
