It is currently Mon Jun 18, 2018 8:53 am
PostPosted: Thu Sep 08, 2011 9:16 pm
Has thanked: 11 times
i have a grant vortex combi boiler 3 yrs old. we have a problem with the low pressure light coming on. there is just over 1 bar in the system but when the pump gets hot it trips out. we have let it cool down and reset it, but the same happens. has the pump had it, can i test it or is it something else? Many thanks!!
PostPosted: Thu Sep 08, 2011 9:22 pm
Has thanked: 422 times
Been thanked: 3903 times
Take the cold fill pressure up to 1.3 bar. then tell us what happens.
When you say pump do you mean for the heating.
Is the boiler cutting out on overheat.
Are you having to top the pressure up.
PostPosted: Sat Sep 10, 2011 12:51 pm
i have increased the pressure to 1.3 bar. the boiler fires up, central heating pump gets hot and heating works ok. but still no hot water. i have reset the boiler (( button bottom left?)combi condensor 26) still no hot water, cooled down and retried. still not right. low pressure light seems to be on all the time, but pressure gauge when heating up goes to about 2 bar. any ideas? thanks.
PostPosted: Sat Sep 10, 2011 1:01 pm
Which model is it.
Are you in a hard water area.
Sounds like a problem with the plate HX or divertor valve
PostPosted: Sat Sep 10, 2011 1:34 pm
it is grant vortex condensing combi 26. The water is mid to hard water so could be scaled up?
can i test anything?
thanks
PostPosted: Sat Sep 10, 2011 1:47 pm
Check the flow switch and blending valve, I think the later is adjustable.
For this message the author thescruff has received gratitude : Quest
PostPosted: Sat Sep 10, 2011 3:31 pm
how do i check these, is it easy to get to? the flow to the hot tap has not changed, just not warm or hot. i have noticed that as soon as you turn the hot water store switch on the low pressure light comes on, regardless of the pressure or temperature. is this any help to you?
thanks again
PostPosted: Sat Sep 10, 2011 3:39 pm
Would be best to get a guy in really, as one needs to be in front of it, they are easy to work on for the most part.
Don't know why the low pressure light comes on, have you checked the air vents on the boiler.
Users browsing this forum: SimBed and 2 guests
