Page 1 of 1
[ 5 posts ] |
| Author |
Message |
tequila
Posted: Sat Sep 10, 2011 10:15 am |
| Newly registered Member |
Joined: Wed Jan 07, 2009 2:04 pm Posts: 85 Location: Essex Has thanked: 0 times Been thanked: 0 times
Hi guy's and gals. I need a new mower. My last one a mountfield has just given up on me ...after two years ...not bad considering it's used everyday. I just ordered the same one over the net ..( as I cannot find it locally and it seems that Mountfield no longer make it ) but it failed on me after ten mins and had to send it back ...so no more internet buying of mowers for me as I now have no mower for Monday :-( Anyway to cut a long story short I need an 18" self propelled, min cut needs to be 20mm ( most are 25mm... but I have some customers insist on a shorter cut! ... Oh and not too heavy. I'm looking at the Honda Izy Honda Izy 18 46SD Alko AL-KO 4610HPD and the Toro 20637 48cm Self Drive Mower
Many thanks for the help. Martin
| Top |
Posted: Sat Sep 10, 2011 10:43 am |
| Senior Member |
Joined: Fri Jan 20, 2006 5:51 pm Posts: 3207 Location: Essex Has thanked: 17 times Been thanked: 264 times
I would go for the Toro as I prefer Briggs and Stratton engines. I have found Honda engines not to be as good over the years. As you use your mower every day you might consider changing the air cleaner filter regularly and perhaps giving it an oil change half way through the season. http://www.abbeygardensales.co.uk/rotar ... 20637.aspx Good price for it here. DWD
| Top |
register or
log in
diggerdog36
Posted: Sat Sep 10, 2011 11:43 am |
| Senior Member |
Joined: Sun Jun 27, 2010 7:55 am Posts: 134 Location: Clara Vale Has thanked: 12 times Been thanked: 4 times
Ive literally just given away a Mountfield HP470 mower, it was a 2005 with a Briggs and Stratton, I would definitely have another if I had the need for a mower!! No problems at all with it!
| Top |
register or
log in
mikew1972
Posted: Sat Sep 10, 2011 12:02 pm |
| Senior Member |
Joined: Sun Jan 27, 2008 5:54 pm Posts: 1051 Location: North West Has thanked: 0 times Been thanked: 69 times
Mountfield have a 2 year manufacturers warranty. (not for professional use ...if you admit to it) You don't say if yours was just under or just over 2 years old. Either way it might be worth phoning them? The Hoda izy would normally be considered a profesional mower and I'm sure is the dearest of the 3, the others you list for home use but I've never owned any on your list myself.
_________________ Mike
| Top |
register or
log in
tequila
Posted: Sat Sep 10, 2011 12:23 pm |
Believe me Mike, they would know it has had two years pro use... poor thing, but it has been superb have to say!
| Top |
register or
log in
Page 1 of 1
[ 5 posts ] |
