Page 1 of 1
[ 8 posts ] |
| Author |
Message |
Track
Posted: Sat Jan 28, 2012 7:06 am |
| Newly registered Member |
Joined: Fri Jan 15, 2010 1:21 pm Posts: 64 Has thanked: 4 times Been thanked: 0 times
I find that, even with my 36 TPI T-blades, my GST 135 BCE still doesn't leave my sheet metal as smooth as glass.
I have used several things, including a Dremel with grinding attachments, but have not gotten the result I want.
With wood, it couldn't be easier. I use my Bosch GEX 125 with 240-grit wood sandpaper, and it couldn't be smoother.
Now I just have to find something equally good for metal.
Thank you.
| Top |
colin allen
Posted: Sat Jan 28, 2012 9:03 am |
Joined: Sat Jan 21, 2012 8:44 am Posts: 5 Has thanked: 2 times Been thanked: 0 times
hi track i used to be a sheet metal worker and the simplist way is to use a very fine file. there aint much else. ok colin allen
| Top |
register or
log in
Hitch
Posted: Sat Jan 28, 2012 11:54 am |
| Senior Member |
Joined: Mon Jan 16, 2006 8:16 pm Posts: 4671 Location: Somerset Has thanked: 6 times Been thanked: 108 times
Agree with Colin, a coarse file to flatten the cut, then a finer file to clean it up. Used with the handle pointing as near to the line of the sheet edge.
_________________ Why isn't the number 11 pronounced onety one?
| Top |
register or
log in
EJJ150847
Posted: Sat Jan 28, 2012 1:27 pm |
| Senior Member |
Joined: Fri Jan 04, 2008 10:32 am Posts: 3032 Location: Fareham, Hampshire Has thanked: 2 times Been thanked: 61 times
We used to rub the file with chalk to get a smoother finish, especially on brass or ally.
John
_________________ Growing old is compulsory, growing up is not!
| Top |
register or
log in
Hitch
Posted: Sat Jan 28, 2012 9:08 pm |
| Senior Member |
Bit of chalk now and then stops it clogging, good tip there
| Top |
register or
log in
Track
Posted: Sun Jan 29, 2012 6:36 am |
Thanks guys.
Do you know where I could find a fine metal file?
Also, a crazy idea - are there metal sanding discs for my GEX 125? I love the finish I get with it on wood.
| Top |
register or
log in
thescruff
Posted: Sun Jan 29, 2012 7:35 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39982 Has thanked: 187 times Been thanked: 2113 times
I used an oil stone to polish the edge on a sheet I was working on.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Hitch
Posted: Sun Jan 29, 2012 10:19 am |
| Senior Member |
I dont see why you couldnt use a normal disc, although it would wear out quickly using it on a sheet edge.
As for fine files, any decent toolshop should have some. Bahco are half decent, well priced, and come with the handles fitted.
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
