-> Painting & Decorating Forum |
| Author |
Message |
stingray316 Junior Member
Posted: Mon Sep 01, 2008 8:04 pm Post subject: Good exterior paint |
| Painting the outside windows again and would like to know what others find a good paint to use. The last time they were painted l used dulex flexible undercoat and gloss but l thought it was hard to paint with, to thick and not running freely through the brush. Since it's got a gloss finish on it already does it need a good rub down before applying a undercoat this time and what about water based exterior paints any good ones l could try..... |
| Back to top |
Telmay Senior Member
Joined: 09 Mar 2007 Posts: 2469 Location: Worthing, West Sussex
Posted: Mon Sep 01, 2008 8:15 pm Post subject: |
Hello,
Dulux weathershield in my opinion is one of the best, and yes you will still need to rub the windows with a bit of abrasive to key the surface prior to undercoating. Think of it as a system, the undercoat grips to the old surface whilst the gloss is better applied to the undercoat, gloss on gloss isnt always a good idea, unless of course you putting on two coats and de-nibbing at the time of decoration. If you want to try waterbased then Sadolin Superdec is what I would recommend, although they call it gloss its more of a satin, but slight rub down to key and then two coats of the Superdec. The paint is specially formulated to naturally break down so wont crack or blister in time, and the next time you decorate it will only need one coat of the Superdec to refresh the whole lot.
Hope this helps
Tel _________________ "Where would we be without rules?
France! And where would we be with too many rules? Germany!" |
| Back to top |
Posted: Mon Sep 01, 2008 9:03 pm Post subject: |
| What would you recommend as a good water based undercoat and will solvent based gloss be ok on water based undercoat. l know dulux is good paint but when l used dulex flexible undercoat and gloss last time it was hard work on the brush, thick and not running off the brush as easy as some l have used before... |
| Back to top |
Posted: Mon Sep 01, 2008 9:04 pm Post subject: |
You can just use their trade undercoat mate and trade weathershield will give you no grief. _________________ "Where would we be without rules?
| Back to top |
Woods of York Junior Member
Posted: Sat Sep 06, 2008 3:48 pm Post subject: |
| All of our guys use nothing but Dulux. Only the best.....i actually found the Weathersheild to be quite thin. |
| Back to top |
Posted: Sat Sep 06, 2008 3:53 pm Post subject: |
Thin but very durable, if you have a bad surface to cover two coats of undercoat are better than two of gloss IMO _________________ "Where would we be without rules?
| Back to top |
Posted: Sat Sep 06, 2008 10:29 pm Post subject: |
| I completely agree.........the Weathershield gloss looks great for ages. |
| Back to top |
gixer750ws Junior Member
Posted: Sun Sep 07, 2008 6:58 pm Post subject: |
| i think most people agree,weathersheild is probably the best on the market |
| Back to top |
