It is currently Thu May 24, 2012 6:48 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: glowworn 30 sx leak
PostPosted: Wed Jan 18, 2012 10:12 pm
Has thanked: 2 times
Hi, I'm new here so please be gentle with me,I have probs with my glow worm 30 sx boiler, I keep losing pressure with water dripping throu the tundish, my plumber today replaced the PRV but it's still leaking . any ideas please. :scratch:
 Post subject: Re: glowworn 30 sx leak
PostPosted: Wed Jan 18, 2012 10:40 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
What does the pressure rise to when the heating is turned on, say starting at 1.3bar cold.
The plumb er should have checked it and the expansion vessel.
PostPosted: Thu Jan 19, 2012 7:23 pm
0.9 cold going up to about 1.3/1.4 when running. what pressure should the expansion vessel be set at?
PostPosted: Thu Jan 19, 2012 7:56 pm
Has thanked: 4 times
Been thanked: 39 times
1.4 bar wouldn't trigger the PRV! :huh: Are you sure he replaced it?
Your problem is now our problem
PostPosted: Thu Jan 19, 2012 7:57 pm
OAP
Did the plumber actually change the pressure relief valve or just play with it, they seldom reseal once they are set off.
If it's a new one, then it's either duff or the pressure is rising to above 3 bar.
best to get the plumber back to have another look
For this message the author thescruff has received gratitude : woodbutcher-rob
PostPosted: Thu Jan 19, 2012 8:59 pm
No he deffo change it, I never left his side, I actually think I've got other problems, got home tonight and towels under boiler( in airing cup'd) were wet so leak is in boiler? Also water passing throu' tundish is stone cold so is this coming from elsewhere, PRV's from mains supply, pressurised cyl and boiler are all connected to same tundish.
PostPosted: Thu Jan 19, 2012 9:12 pm
:director: Got any pics?
PostPosted: Thu Jan 19, 2012 9:27 pm
OAP
Agreed some pics would be useful
Could it be the cylinder letting by, the make and model of that as well please.
PostPosted: Fri Jan 20, 2012 6:42 am
Wierder and wierder, all seams OK this morning, we are away for weekend so will see sunday evening.
Thanks for your help.
P.s. cyl. is Telford tornado.
PostPosted: Fri Jan 20, 2012 8:28 am
OAP
Right so the problem is most likely to be the cylinder.
It has an internal expansion vessel, follow the instructions to reinstate it or get a plumber with a G3 unvented qualification.
PostPosted: Sat Jan 28, 2012 5:37 pm
Have ordered a new expansion vessel. old one will not hold pressure (tried pumping it up), also having a non-return valve fitted on hot out of cylinder. how much should I pay for vessel? telford exp19
PostPosted: Sat Jan 28, 2012 5:44 pm
OAP
Would sooner see a pic or two and there shouldn't be a non-return valve on the hot out.
Are you meaning the white vessel.
PostPosted: Sat Jan 28, 2012 6:30 pm
Has thanked: 76 times
Been thanked: 372 times
Ive seen lots of nrvs fitted on the outlet of UVs where the cold supply isn't taken off the balanced feed from the valve. Then someone fits a cheap mixer and the pressure backfeeds to the cylinder.
PostPosted: Wed Feb 01, 2012 11:21 am
New expansion vessel and check valve fitted today , so far so good ( insert fingerscrossedsmiley)
Cant locate leak in boiler but seems to be coming from black plastic manifold only a very slight drip takes about 3days to drop enough to stop boiler working. Got a piccy to upload but dont know how to. :scratch:
PostPosted: Wed Feb 01, 2012 2:20 pm
UHM Super Moderator
Has thanked: 30 times
Been thanked: 55 times
posting-pictures-t24811.html
Users browsing this forum: Google [Bot] and 42 guests
