It is currently Mon Mar 25, 2019 8:29 pm
PostPosted: Fri May 25, 2018 4:21 pm
I have a steady loss of pressure but can't see any sign of leaks what can I do.I can't see how to isolate the boile in case its that,.Is there anything I can do ,my system is quite old apart from the boiler which is two years old ,all the pipes are under a parquet floor.
PostPosted: Fri May 25, 2018 5:26 pm
Has thanked: 840 times
Been thanked: 941 times
Check the 15mm copper pipe outside from the pressure relief valve for dripping.
If you cant isolate your boiler, there is not much else you can check apart from obvious looking at all the rad valve joints etc.
Dave
www.drlgas.co.uk
PostPosted: Mon May 28, 2018 6:30 pm
Has thanked: 1535 times
Been thanked: 3869 times
such a small loss would indicate a tiny weep around a radiator valve, fairly common as with the heating off the pipework contracts, take the plastic covers off the valves and run your finger around the spindles. check all the compression joints.
