It is currently Thu Jul 19, 2018 10:45 am
PostPosted: Sat Jul 01, 2017 2:19 pm
Hi , I had a leak on the expansion chamber , (which had been leaking slightly for some time by the looks ) anyway I cleaned up the spill and replaced the expansion tank and restarted the boiler ... The boiler showed F9 and F22 ... I then replaced the low pressure sensor and cleaned the return thermistor and replaced it back ... these errors then cleared .... I reset the boiler and now the boiler goes to start but fails to fire , I can see the ignition sparking through the small combustion window and the gas supply is on ... yet it doesnt fire up and closes down (as per the manual ) after the 5th attempt and now shows the error code F1 ??
Not sure now what to look at at this would indicate either a gas fault or no ignition but I have both .??
Any suggestions really appreciated
regards Paul
PostPosted: Sat Jul 01, 2017 7:36 pm
Has thanked: 811 times
Been thanked: 886 times
I can only recommend getting a RGI in to fix as it sounds gas related.
Dave
www.drlgas.co.uk
