It is currently Sat Feb 17, 2018 9:16 pm
Visit Thermo worx
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Sat Mar 05, 2011 3:45 pm
Has thanked: 2 times
i have a betacom 30 and when the selector switch is in heating mode the boiler fires up and is fine and when you run the hotwater tap nothing happens in continues to circulate the heating,when you put the selector over to the hotwater only nothing happens, the green on light is on and no fault lights are on,pump dont run fan dont run nothing,like there aint even a demand for hotwater, i think the diverter is fine cause when i put the heating on and push the pin on the diverter in manually it goes round the hotwater and not the heating and when i release it vice versa, takes a while for the hotwater to get hot so i think i need to change the heatexchanger but i think it needs a pcb to sort the hotwater out, before buying one does anyone have any ideas or checks i could do first
thanks
PostPosted: Sat Mar 05, 2011 4:11 pm
Has thanked: 422 times
Been thanked: 3902 times
The heating guys will be around but I would say the flow sensor or diverter valve.
PostPosted: Sat Mar 05, 2011 5:13 pm
Has thanked: 768 times
Been thanked: 821 times
First thing I would check is the DHW flow sensor, as your boiler sounds as if it does not even know a hot tap is being run.
Dave
www.drlgas.co.uk
For this message the author gas4you has received gratitude : terryp01
PostPosted: Sat Mar 05, 2011 5:37 pm
Has thanked: 4 times
Been thanked: 37 times
It will be the DHW flow sensor very fiddly on this boiler
For this message the author gasspark has received gratitude : terryp01
PostPosted: Sat Mar 05, 2011 7:36 pm
is that on the clip on the side of the diverter valve,i am a gas engineer but i do install never breakdown so appreciate the advice guys, can i test that by linking it out and seeing if it works or would you just buy one and give it a try first, you know how much one would be about £20 at a guess?
cheers guys
PostPosted: Sat Mar 05, 2011 8:13 pm
GWORM 0020061608 FLOW SENSOR
£41.39 + VAT trade at Parts center
£69.57 + VAT retail
Dave
www.drlgas.co.uk
PostPosted: Sat Mar 05, 2011 8:34 pm
dave if i linked out the flow switch would the boiler then fire in theory if it was the flow switch or not the case
cheers
PostPosted: Sun Mar 06, 2011 11:42 pm
Gas/Heating Expert
Has thanked: 27 times
Been thanked: 295 times
The flow sensor is a turbine which gives a succession of pulses from the Hall effect sensor when activated by the permanent magnet on the rotor rotating!
Shorting together any of the three wires is likely to do damage to the PCB.
Tony
PostPosted: Mon Mar 07, 2011 12:05 am
Has thanked: 6 times
Been thanked: 39 times
as this is really a heatline boiler....http://www.abcotuk.co.uk/Product.aspx?ProductId=P931&catid=C2
http://www.homegas.co.uk
