Ultimate Handyman Home
Gloss bubbling on front door
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum
madmike
Junior Member
PostPosted: Mon Sep 29, 2008 5:41 pm    Post subject: Gloss bubbling on front door Add User to Ignore List Reply with quote
Hi Guys, just painted a hardwood front door, knotted with patent knotting used dulux trade weathershield stages 1 & 2, and then just normal dulux trade gloss, no probs until the sun came out and now where the knots seem to be the paint is blistering down to the knotting solution. heeeelp. Crying Crying
Back to top
Have Brush Will Travel
PostPosted: Mon Sep 29, 2008 7:52 pm    Post subject: Add User to Ignore List Reply with quote
Is it only on the knotted areas?..because you can have problems if you use the 'primer' over knots..
The primer is meant to be absorbed into the surface, but cant because of the knotting solution, it will just sit there...then when you gloss the gloss has no adhesion to the surface
If you looked at the paint on the back of those bubbles under a microscope youll find a layer of 'primer' stuck to them and not the door.
youll have to scrape of the bubbles..and then prime using using aluminium wood primer, its self knotting so the resin wont stain the surface of the finish paint...fill with exterior grade polyfiller undercoat, rub the whole door down with very fine (320 grade) wet and dry paper then gloss the whole lot again.
(just as a footnote..stabilising solution can do the same thing if its put on a non absorbent surface)
'''No one likes us...we dont care!'''
Last edited by Have Brush Will Travel on Mon Sep 29, 2008 8:10 pm; edited 1 time in total
Back to top
madmike
Junior Member
PostPosted: Mon Sep 29, 2008 8:04 pm    Post subject: Add User to Ignore List Reply with quote
Yes, only seems to be bubbling on the knotted areas ?
Back to top
PostPosted: Mon Sep 29, 2008 8:13 pm    Post subject: Add User to Ignore List Reply with quote
See above Mike..I think the messages have crossed.
Back to top
madmike
Junior Member
PostPosted: Mon Sep 29, 2008 8:19 pm    Post subject: Add User to Ignore List Reply with quote
wow, thanks for the quick reply and great advice. great site only found it this evening. what would be the answer in the future. just use aluminium primer and no knotting at all?
Back to top
PostPosted: Mon Sep 29, 2008 8:38 pm    Post subject: Add User to Ignore List Reply with quote
Yes mate
Back to top
madmike
Junior Member
PostPosted: Mon Sep 29, 2008 8:44 pm    Post subject: Add User to Ignore List Reply with quote
thanks HBWT. looks like ive got a bit of scrapping to do, oh well wont make that mistake again. Laughing
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum All times are GMT
Page 1 of 1
