-> Plumbing Forum |
| Author |
Message |
Jaeger_S2k Senior Member
Joined: 19 Nov 2006 Posts: 2786 Location: North West, England, United Kingdom
Posted: Sat Nov 10, 2007 12:25 am Post subject: Gas Torch Recommendations? |
Have been doing a fair bit of soldering and lots more to come over the next 3 weeks or so and my MAPP Gas and torch are getting old and are a bit big and HOT.
What torch would you recommend? _________________ Jaeger.
FSBF |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
| Back to top |
uncle buck Senior Member
Joined: 28 Feb 2007 Posts: 106 Location: Newcastle T&W
Posted: Sun Nov 18, 2007 5:51 pm Post subject: |
Some good deals on Rothenberger Superfire 2 torches on ebay £40 ish delivered if you keep your eyes peeled....but maybe thats what you have already?
You can get an adaptor so that you can use the Rothenberger torches with the Primus 2000 bottles. |
| Back to top |
Posted: Sun Nov 18, 2007 6:14 pm Post subject: |
I have this little fella...
using with Mapp at present, I'm getting more comfortable with it now and I think I'll stick with it. Also hitting a number of 28mm fittings currently and the Mapp is proving the preferred cooking method!
Interestingly looked into tank tube and torch make-ups and they look like a good option, may explore that some more later. _________________ Jaeger.
FSBF |
| Back to top |
Posted: Sun Nov 18, 2007 7:18 pm Post subject: |
Yeah that's virtually identical except you have a flame adjuster on the superfire 2.
You can get an adaptor so that you can turn the superfire 2 torch into a tube set up....so it will fit your torch also....
However I can’t find it anywhere on the internet even on the Rothenberger site but that doesn’t mean that one isn’t available.
The Rothenberger part number for the adaptor is 3.5653  |
| Back to top |
Posted: Wed Nov 21, 2007 11:55 pm Post subject: |
| uncle buck wrote: |
Thanks UB _________________ Jaeger.
FSBF |
| Back to top |
Hoovie Devon DIYer
Posted: Thu Nov 22, 2007 8:25 am Post subject: |
Quick Question.
Jaegar - you made mention of 28mm fittings and sort of hinted that your previous torch was not up to job. I am I reading between the lines wrong?
I have a typical basic DIY-style gas torch (from wickes about 1o+ years ago) using standard cylinders - old style with adjustable nozzle and match to light.
Do you think I will have problems with making decent solder joints on 28mm copper?
Been ok on 15mm but 28mm probably whole new ball game!
Got my final (planned) bit of pipework to complete in next couple of months - which is all 28mm. _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
Posted: Thu Nov 22, 2007 9:43 pm Post subject: |
Hi Hoovie,
Other way round, the MAPP is dealing with the 28mm couplings just fine.
I've not used a smaller torch for some time, but would think it could be hard work on a larger fitting, may even take a bit to get a 22mm fitting.
Ideally the solder shouldn't go near the fitting till the flux boils, I see flux boiling within 5 to 10 sec although it's difficult to say, have a number of 22 to do tomorrow under the floor I'll try and time them better. It'll give me something to do. If I get finished on them then I'll be building 2 gas supply lines through and around a bay window in 28mm so will try and get a timing there too.
Maybe Hint and BS have some timings? _________________ Jaeger.
FSBF |
| Back to top |
Hoovie Devon DIYer
Posted: Thu Nov 22, 2007 10:45 pm Post subject: |
I will try a few test ones before I do the real thing - going for end feed as well Don't think they do 28mm in yorkshires  _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
| Back to top |
tim'll fix it BANNED
Joined: 18 Jan 2006 Posts: 2137 Location: Leicestershire
Posted: Fri Nov 23, 2007 9:47 pm Post subject: |
| Hoovie wrote: |
I will try a few test ones before I do the real thing - going for end feed as well Don't think they do 28mm in yorkshires  |
well they wouldnt yorkshires are for bodgers and 28mm is pro stuff really. I have soldered 28mm with a bog standard diy torch in the past, agreed a MAPP torch will be quicker but you will be able to do it with what you have _________________ Decking |
| Back to top |
