Ultimate Handyman Home
gas fire
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
fudrick
Junior Member
PostPosted: Wed Feb 14, 2007 7:53 pm    Post subject: gas fire Add User to Ignore List Reply with quote
i have a gas fire , an inbuilt type with fake coals. can i take the gas part out and just put in an open fire, the problem i have is that it is not real firebrick, but some other material that looks like bricks , maybe asbestos, not sure, any help please
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Wed Feb 14, 2007 9:06 pm    Post subject: Add User to Ignore List Reply with quote
NO, you would have to remove the fire completely, and fit a standard open fire grate!
The flue outlet on the gas fire, is not designed for an open fire, and may not work correctly for solid fuel. Remember ANY burning process can produce deadly Carbon Monoxide, not just gas.
www.hintonheating.com
Back to top
fudrick
Junior Member
PostPosted: Wed Feb 14, 2007 9:15 pm    Post subject: Add User to Ignore List Reply with quote
thanks hh , just had chimney cleaned and tested , was fine, and i think it was used for solid fuel before, the look alike brick is shaped for a fire , but not sure if it could stand the heat of an open fire
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Wed Feb 14, 2007 9:32 pm    Post subject: Add User to Ignore List Reply with quote
Could you post a picture of the fire, taken from a low angle looking toward the outlet into the chimney.
There are many types of gas fire, so would be better to see it, to advise.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
