-> Plumbing Forum |
| Author |
Message |
Ricky Junior Member
Joined: 01 Dec 2007 Posts: 17 Location: West Yorkshire
Posted: Sat Dec 01, 2007 11:15 am Post subject: Gas Fire Flue |
Had British gas in to service gas fire. The fitter informed me that the size of flue in the brickwork at the rear of the fire did not come within the Regulation. He said it was too small one way. Would any of you kind Forum Members be able to help, Re correct size.
Many Thanks |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
Posted: Sat Dec 01, 2007 5:48 pm Post subject: |
exactly what did he write on the NCS (Not to Current Standards) report??
Did he turn the fire off?
If you dont understand, you should ring British Gas to explain.
Do you mean the distance from the flue to an obstruction, is too small? _________________ www.hintonheating.com
| Back to top |
Ricky Junior Member
Posted: Sat Dec 01, 2007 6:38 pm Post subject: |
Thanks for the reply Hinton Heating.
On engineers report as follows
Condition as Left--------At Risk
Capped/Turned Off-----Not Turned Off
Safety Report-----------Left At Risk Due To Throat Size Of Chimney |
| Back to top |
Posted: Sat Dec 01, 2007 6:52 pm Post subject: |
ok, i know what he means... basically the crossectional area of the chinmey is too small, meaning that the amount of fumes may not get drawn up properly.
Do you have the instructions for the fire? it may give a minium size in there. _________________ www.hintonheating.com
| Back to top |
Ricky Junior Member
Posted: Sat Dec 01, 2007 7:06 pm Post subject: |
Thanks Hinton Heating
Will have a look for manual
Many Thanks Again |
| Back to top |
