Ultimate Handyman Home
Garage Conversion
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
rak_diy
Junior Member
PostPosted: Fri Mar 23, 2007 3:41 pm    Post subject: Garage Conversion Add User to Ignore List Reply with quote
Hello
I am converting half of my garage into an office, it is a single skin structure with a flat roof. Can anyone give me some guidance on a few things.
I am after know the thickness and type of inuslation that I will need on the walls and floor. Also what sort of construction will I need with regards to insulation and boarding everything, ie DPM, ventilation gaps etc.
Finally the stud wall that will be across the garage will be fixed into an outside wall on one side and an inside wall on the other. Do I need to put a DPM on the walls before attaching the vertical timbers and do I need to use an specific type of fixing to do this with it being a potentially damp outside wall?
Many Thanks
Back to top
panlid
PostPosted: Fri Mar 23, 2007 7:16 pm    Post subject: Add User to Ignore List Reply with quote
if you pop back on monday i will give you all your answers. its friday night and its been a hard week. i cant think work now Wink Laughing Thumbright
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Fri Mar 23, 2007 7:19 pm    Post subject: Add User to Ignore List Reply with quote
Have a beer for me too Panlid! Laughing
www.hintonheating.com
Back to top
panlid
PostPosted: Fri Mar 23, 2007 10:35 pm    Post subject: Add User to Ignore List Reply with quote
cant believe i organised to look at 3 jobs tonight. and it was my 5 year ols birthday party at 4 as well. phoned them all up with excuses Wink
Back to top
skiking
PostPosted: Sat Mar 24, 2007 9:51 am    Post subject: Add User to Ignore List Reply with quote
At least you phoned Thumbright ....most just wouldn't turn up Bang Head
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sat Mar 24, 2007 10:14 am    Post subject: Add User to Ignore List Reply with quote
remember they're not excuses... but reasons! (well maybe not!)
Its only good customer relations to keep the customer informed!
Back to top
panlid
PostPosted: Sat Mar 24, 2007 10:58 am    Post subject: Add User to Ignore List Reply with quote
hints, my 'reason' was that my budgie had escaped its cage and the kids were distraught Thumbright
thats why in the building trade they are known as 'excuses' Laughing
Back to top
rak_diy
Junior Member
PostPosted: Mon Mar 26, 2007 9:51 am    Post subject: Add User to Ignore List Reply with quote
Hehehe, hope you caught you budgie!!!!!!
Any thoughts on the garage conversion?
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Mon Mar 26, 2007 4:37 pm    Post subject: Add User to Ignore List Reply with quote
I hepled my friend the exact same job.
we used a plastic DPC, which went up the walls by a foot, across the floor, then a screed over the top.
We assembled 2" x2" wooden frames and mounted off the walls leaving a cavity of an inch.
we used 2" insulated sheets on between the wall stud work, then covered with silver backed plasterboard.
The roof we used 4" thick insulated board, between the exsisting joints, again using silver backed plasterboard.
The whole room was then skimmed.
So far been very warm & toasty in there!
Back to top
panlid
PostPosted: Mon Mar 26, 2007 5:21 pm    Post subject: Add User to Ignore List Reply with quote
first off build your floor. but a sheet of plastic visquine down coming up the edges like hints say by about a foot. then get some joists cut going from side to side. use something like 5x2. i then chop aload of different sizes blocks and put them under the joists. once you get one right gripfil the blocks in place. once all your joists are in and level then put some 150mm loft insulation in between the joists. now screw 8x2 t&g chipboard flooring to it. theres your floor.
now this is easier to fit the walls. just knock up some stud walls and fix the to the floor and to the ceiling joists. no fixings to the external wall. leave a gap of about 1" between the bricks and joists. then fit some loft insulation in between the joists. then plasterboard the walls using 1/2" vapour check boards. that is the stuff with foil on the back.
as for the ceiling, with it bein a flat roof you have to be careful. the cheapest way is to screw some 1" batterns across the joists and insulate between the joists keeping the insulation up to the roof boards. then plasterboard using the 1/2 vapourboard again. a tip, get someone to help or find a supplier that supplies 6x3 vapour board as it is easier to fit on your own. the batterns going across allow air to go from joist gap to joist gap so you wont get any dead spots. then fit a couple of facia vents at the front and a couple at the back. your ceiling will now have good airflow.
there are lots of ways to do a garage conversion but this from my expierience is the quickest and cheapest way,.
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Mon Mar 26, 2007 5:38 pm    Post subject: Add User to Ignore List Reply with quote
very similar to the way we did it, but instead of loft insulation, we used panels like this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110107082654
easy to cut with a saw, and wedges between the wall/ceiling joists nicely
Back to top
panlid
PostPosted: Mon Mar 26, 2007 5:53 pm    Post subject: Add User to Ignore List Reply with quote
ive used that sometimes. it is dearer than loft insulation but is good stuff. depends on how muchh you want to spend.
loft insulation is easy in the walls as you just build the studs at 400 centres and it sits in nicely. by putting cross batterns on the ceiling that keeps it up in the roof space. less itchy though Thumbright
Back to top
rak_diy
Junior Member
PostPosted: Tue Mar 27, 2007 7:48 am    Post subject: Add User to Ignore List Reply with quote
Thanks everyone that's great. Just one question though Panlid. You said about the roof and using vapour control plasterboard. I have already had a new roof put of the garage and when this was done I asked they to put a warm deck in at the time and this was done with 100mm King span insultation which was a vapour control built it. With this is it OK just to plasterboard internally with just standard plasterboard. This will have a 100mm air gap between the joists. Would all this be OK?
Back to top
panlid
PostPosted: Tue Mar 27, 2007 7:37 pm    Post subject: Add User to Ignore List Reply with quote
just so i understand, are you saying the ceiling is already boarded and insulated using kingspan?
Back to top
rak_diy
Junior Member
PostPosted: Wed Mar 28, 2007 9:19 am    Post subject: Add User to Ignore List Reply with quote
The roof is insulated on the outside with King Span but the inside isn't board yet
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Goto page 1, 2  Next
Page 1 of 2
