-> Carpentry/Joinery Forum |
| Author |
Message |
Hoovie Devon DIYer
Posted: Mon Oct 22, 2007 7:20 pm Post subject: |
| Hinton Heating wrote: |
maybe for draft prevention.
As the downstairs should be as warm as upstairs, so heat transfer isnt a problem. where as the under the downstairs boards will be cold, and gaps are not good there! |
I guess you got it there, Hinton - maybe before the days on central heating - which would coincide with bare floorboards looking at the way they tend to be stained - in pre-war houses at least, heat could maybe rise up a little throught the ceiling and squeeze through the gaps in the floor better.
Thank god for radiators! _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
Welsh Decorator Senior Member
Posted: Mon Oct 22, 2007 7:37 pm Post subject: |
Don't you mean the other way around
Upstairs boarded and downstairs a solid floor.  _________________ I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it! |
| Back to top |
Posted: Mon Oct 22, 2007 7:38 pm Post subject: |
Why did this post twice, oh well. _________________ I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it! |
| Back to top |
Hoovie Devon DIYer
Posted: Tue Oct 23, 2007 8:42 am Post subject: |
| Welsh Decorator wrote: |
Upstairs boarded and downstairs a solid floor.  |
If you meant my posting, most of my DIY work has been with houses that have timber floors top and bottom (1930's type), rather then concrete.
Out of interest, when you have a suspended timber floorboards on the ground floor, what should the ground look like underneath? should it be a poured concrete or just left as compacted earth? _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
| Back to top |
Wood Magnet Senior Member
Posted: Tue Oct 23, 2007 3:03 pm Post subject: |
Hi Edz, the only other thing i can suggest is
string or thin rope soaked in pva and then
pushed into the gaps. You can dye the string
beforehand to match the boards.  _________________ People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's. |
| Back to top |
Posted: Tue Oct 23, 2007 5:45 pm Post subject: |
Hi Hoovie, all the timber floors that I have seen or worked on have either been dirt or concreted under the joisting, the main thing is, MAKE sure that the air vents are clear of any muck ect.
If these get bloked, then the chances are that the timber will be a great risk of various rot attac, dry rot being the worsed to try to stop  _________________ I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it! |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You can attach files in this forum You can download files in this forum
