It is currently Mon Jul 23, 2018 5:08 am
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Tue Oct 03, 2017 6:14 pm
Has thanked: 54 times
Been thanked: 23 times
I'm ready to burn my front door on the fire and fit a PVC one....
ok slight exaggeration but i'm really at the end of my tether here....
I've spent the past 2 weeks on this s*dding door.
Stripped completely and sanded/cleaned... prepped like there was no tomorrow!
2 coats of FB resin blocker
2 coats of FB exterior undercoat
3 coats of FB top coat colour
The door has been back on its hinges TWO DAYS (had left it indoors to set for about a week whilst I did the rear of it.
Small bit of sun this afternoon and this monstrosity happens! pics below.... TWO DAYS!!
P*ssed off is an understatement. Im going to have to strip it and start again.
Can anyone recommend please a proper primer/treatment to help combat this bubbling as clearly the FB resin blocker can't handle it! The door is in the sun all afternoon to sunset so I need something hardcore to seal the door.....
So so so annoyed! argghhhh
all and any advice welcomed please thank you, we are selling the house so need a decent front door finish! Would like to keep the same colour.
Is it a lost cause, and am I going to have to get the door stripped and just kept as treated wood!?
(some of the bubbles were huge... i put small slits in them with a stanley blade and pressed the air out. No liquid or sap came out... it was just air in them. Lifted back to the bare door so def a primer / resin block fail)
PostPosted: Tue Oct 03, 2017 6:45 pm
Do I strip and use an aluminum wood primer to start again with?
or perhaps Linseed oil paint?
PostPosted: Tue Oct 03, 2017 7:40 pm
Elephant Man
Has thanked: 600 times
Been thanked: 1348 times
What did you use to strip the paint, and what was the door cleaned off with? It looks like there may have been residual chemical stripper in the grain, but given the level of preparation you mention, it seems odd.
Nihil expectore in omnibus
For this message the author dynamod has received gratitude : multiman
PostPosted: Tue Oct 03, 2017 7:59 pm
Sanded it all back when I prepped.
It was exhausting!
PostPosted: Wed Oct 04, 2017 7:53 am
Has thanked: 230 times
Been thanked: 227 times
Not quite enough - Nightmare!!!
Do you just clean off the stripper or is there a neutraliser?
PostPosted: Wed Oct 04, 2017 8:07 am
No chemicals were used to strip the door. I used 60/80/120 grit paper.
Cleaned off with turps.
I really don't have the energy to take the thing off again and strip it!
PostPosted: Wed Oct 04, 2017 8:51 am
Has thanked: 565 times
Been thanked: 1668 times
Dave, bin it and get a new door. I would have put a sledgehammer though it :angryfire:
:thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : multiman
PostPosted: Wed Oct 04, 2017 8:57 am
I did eye up the lump hammer in the shed!!...
Can't bin the door... it's part of the property.
Dropped some linseed paint companies an email to see what they say....
PostPosted: Wed Oct 04, 2017 10:04 am
Been thanked: 34 times
You said you cleaned it off with "Turps", Turps is an oily substance and it could have soaked into the wood, when the sun came out perhaps the heat lifted the turps out of the wood hence blotches :dunno: just a thought, I would have cleaned it with a solvent, which would have evaporated before having chance to soak into the wood.
For this message the author Nos has received gratitude : multiman
PostPosted: Wed Oct 04, 2017 10:17 am
Sorry my mistake, I used Methylated Spirit (lightly)
For this message the author davemulheran has received gratitude : multiman
PostPosted: Wed Oct 04, 2017 7:00 pm
Has thanked: 1452 times
Been thanked: 3725 times
:dunno: I had a door to re-dec about 6 years ago now. Post 2010 Voc oil based gloss , full sun (south facing)
Similar issue.
Sanded back and used Zinsser 1-2-3 followed by undercoat and 2 x topcoat. Still looks (almost) as good as the day I did it.
For this message the author wine~o has received thanks - 2: davemulheran, multiman
PostPosted: Wed Oct 04, 2017 7:10 pm
Has thanked: 397 times
Been thanked: 1406 times
Similar issue.
That's to be expected when you travel by Tardis. :roll: :wink:
PostPosted: Thu Oct 05, 2017 7:48 am
Has thanked: 855 times
Been thanked: 453 times
:lol:
PostPosted: Mon Oct 09, 2017 5:30 pm
So do I strip it again and Zinnser... or just use a linseed oil paint ...
PostPosted: Mon Oct 09, 2017 6:06 pm
You'll need to strip (or at least sand back to sound) either way. You are also getting towards the time of year when exterior decorating can be problematic
ie. too damp/cold
