Ultimate Handyman Home
Fridge thermostat replacement - Whirlpool ARG716WP
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> General DIY forum
JeztheRed
Junior Member
PostPosted: Tue Mar 25, 2008 8:10 pm    Post subject: Fridge thermostat replacement - Whirlpool ARG716WP Add User to Ignore List Reply with quote
Hi, can anybody advise me on how I get to the thermostat on my fridge so as I can check/replace it? Is it from the inside or the outside? At a quick glance it is not obvious but a pointer in the right direction may make it so!
Jez
Back to top
JeztheRed
Junior Member
PostPosted: Sat Mar 29, 2008 12:51 pm    Post subject: Sorted Add User to Ignore List Reply with quote
Thumbright
OK guys and gals, I figured it for myself. The housing needs to be pulled forward and out as there are a couple of 'lugs' that hold it in place. Undo a srew holding the plastic conduit and two srews holding the thermostat phial holder, located at the rear of the fridge and full access is available to replace the thermostat. All can be done from inside the cabinet, no removal of panels etc required. Don't forget to unplug the power first!
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> General DIY forum All times are GMT
Page 1 of 1
