It is currently Fri Feb 22, 2019 12:13 am
 Post subject: Fridge Freezer Handles
PostPosted: Sun Oct 07, 2018 6:19 pm
Has thanked: 5 times
My family bought me a Hotpoint Fridge Freezer but the handles are on the side so when it slots into the gap next to my built in cupboards I have to have it forward otherwise I can't open it Can I adapt the handles so they are front facing rather than side facing please
PostPosted: Sun Oct 07, 2018 6:47 pm
Has thanked: 61 times
Been thanked: 648 times
whats the model number ?
edit. what about suction handles ?
eg.
https://www.amazon.co.uk/Beckly-Necessa ... dle+fridge
or
https://www.amazon.co.uk/Starnearby-Sup ... le+suction
For this message the author Bob225 has received gratitude : shamick59
PostPosted: Tue Oct 09, 2018 6:39 am
Thanks. It’s a LAO85 FF1IW model. Good call on sucker handles my only concern is how strong the suckers are and if they are heavy duty enough to open a fridge door
PostPosted: Tue Oct 09, 2018 8:18 am
Has thanked: 410 times
Been thanked: 1501 times
There will be no problem opening a fridge door with them.
I, (and many others) use them (often in bathrooms) to provide stability for disabled people. I've found that they will let go after time so they have to be checked periodically before use in that situation but when fitted to a clean surface they will take the weight (120lb.) of my own personal spastic.
For this message the author ayjay has received thanks - 2: chrrris, shamick59
PostPosted: Tue Oct 09, 2018 12:00 pm
You maybe able to use handles from a similar model (the doors are used on other models)
I will do a bit of digging
What is the distance between the screw holes ?
https://www.ebay.co.uk/itm/New-Smeg-Cap ... SwKflZOZCa
PostPosted: Thu Oct 11, 2018 2:54 pm
Has thanked: 14 times
Been thanked: 55 times
Can you not turn the doors round so the handles are on the other side? Most fridges have this facility, look at the top and you will probably find a screw holding the existing hinge in place and there should be a corresponding hole (plugged) on the other side - straightforward to move the hinge to the other side.
There are no problems - only solutions
PostPosted: Fri Oct 12, 2018 12:38 am
Has thanked: 219 times
Been thanked: 287 times
You, sir, just made me spit a gob-full of tea over my keyboard. It's so rare to see the British, dark sense of humour, in full swing on t'internet these days. :lol:
I'm going to guess that if the fridge is too wide to fit in the available gap with handle on left, it'll probably also be too wide with the handle on the right. :wink:
For this message the author chrrris has received gratitude : shamick59
PostPosted: Fri Oct 12, 2018 8:12 am
I know it's no longer PC to call them Spastics, but that's exactly what my wife is - she even goes to "Spasticity Clinics" and has drugs to treat "Spasticity" as part of her drug regime for dealing with her MS.
https://www.mstrust.org.uk/a-z/spasticity-and-spasms
If the medical profession would come up with a different term, I'd probably use it, but as it is, she's a Spastic.
For this message the author ayjay has received gratitude : shamick59
PostPosted: Fri Oct 12, 2018 3:00 pm
Unfortunately not as there is a wall the otherside
PostPosted: Fri Oct 12, 2018 3:01 pm
Yep you are correct there is a wall the other side
PostPosted: Fri Oct 12, 2018 3:05 pm
https://www.ebay.co.uk/itm/New-Smeg-Caple-Balay-Universal-Fridge-and-Freezer-Door-Handle-fits-most-models/192211699760?hash=item2cc0b5c830:g:USsAAOSwKflZOZCa
I'm at work at mo but will measure tonight thanks
PostPosted: Fri Oct 12, 2018 5:35 pm
I'm going to guess the current PC term will be "MS sufferer" or something (at least in your wife's case...), but these things change so often I can't keep up. On a vaguely similar note, it took me ages to remember which of "dwarf" or "midget" was the one you're allowed to day and which was an insult.
It was more the term "my own personal spastic" that made me chuckle. A brutal honesty that you don't get to see/hear very often these days. I was working at an office of the Spastics Society in Banstead when they were rebranding to "Scope" -- must have been way back in the late 80s or early 90s when political correctness was really beginning to take hold. Can't even remember what I was doing there -- I'm guessing it must have been something to do with computers at that sort of time. I do remember thinking to myself "just don't even talk about it" because I was so afraid of using the wrong terminology and inadvertently insulting someone. Things like that are a minefield, quite unnecessarily IMHO.
PostPosted: Sun Oct 14, 2018 10:06 pm
The distance between the screw centres is 20cm
PostPosted: Mon Oct 15, 2018 7:46 am
Has thanked: 140 times
Been thanked: 167 times
If you are still struggling to find something that will do the job, try these ;
https://www.espares.co.uk/
They supply handles that fit other makes, you just have to send them a photo and a few details and they may be able to help.
Mike
