| Author |
Message |
bright_spark
Posted: Sun Aug 01, 2010 12:22 am |
| Senior Member |
Joined: Tue Jun 02, 2009 10:23 pm Posts: 105 Location: West Midlands Has thanked: 4 times Been thanked: 35 times
Is the earth clamp clamped to the grey sheathing of a cable or to lead piping enclosing a cable??
_________________ Measure twice cut once!
| Top |
dinx67
Posted: Sun Aug 01, 2010 12:30 am |
| Newly registered Member |
Joined: Sat Jul 31, 2010 9:03 pm Posts: 78 Location: Wigan, NW Has thanked: 108 times Been thanked: 1 times
There is only about 3 inches of that cable (under the fuse box) and I've had a little poke at it but I can't tell if it's lead or plastic casing. Is there a way to tell them apart?
| Top |
register or
log in
thescruff
Posted: Sun Aug 01, 2010 12:34 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39135 Has thanked: 181 times Been thanked: 1983 times
Scratch it with a knife, if it's lead it will be bright like a coin.
_________________ --------------------------------------------------------------------------------------------------- If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
register or
log in
thescruff
Posted: Sun Aug 01, 2010 12:51 am |
| OAP |
Scratch it below the tag with a knife
| Top |
register or
log in
register or
log in
thescruff
Posted: Sun Aug 01, 2010 12:55 am |
| OAP |
So it is lead, any idea where the bottom of it goes.
| Top |
register or
log in
dinx67
Posted: Sun Aug 01, 2010 1:02 am |
I didn't realise until looking closely at those pictures that the old lead cabling actually leads up and under the baseboard to which the fuse box is attached. I'm guessing that whoever did the fuse box and new wiring didn't rip out the old one but maybe just cut it back and left it for dead?
The bottom of the cable is about 3 inches long and the lead sheath has been cut back leaving the red and black wires hanging out the bottom. One goes to one white plastic box, the other goes to the other plastic box. Both these boxes are wired to the electricity meter - these are the 'new' things that the meter man fitted a few years ago.
This may be an extremely stupid question but is it possible that the meter man has in some way managed to make an old bit of cabling live again by using it as part of the earth circuit from the meter box to the fuse box?
| Top |
register or
log in
bright_spark
Posted: Sun Aug 01, 2010 1:19 am |
| Senior Member |
Am i right in saying we have now identified both ends of this cable... & the cable... or should i say the lead piping... is not anything to do with the piping running down your lounge wall?
| Top |
register or
log in
bright_spark
Posted: Sun Aug 01, 2010 1:28 am |
| Senior Member |
I will be interested to hear what Rich-Ando makes of this!
| Top |
register or
log in
register or
log in
dinx67
Posted: Sun Aug 01, 2010 1:41 am |
We have identified one end of the lead piping - in the meter cupboard under the stairs. Who knows if the other end is that running down the living room wall? The only way I could check is to take up some floorboards upstairs to see if it is running up the wall, behind the plaster, from the meter cupboard to the upstairs landing. If it does then my guess is that it will run along the floor joists upstairs, through a bedroom, down into the living room. That's another job for tomorrow then... Thanks for all your input and help guys.
| Top |
register or
log in
bright_spark
Posted: Sun Aug 01, 2010 1:50 am |
| Senior Member |
No problem! Check back here tomorrow to see what the other guys have to say but to me it is very suspect & requires attention!!
| Top |
register or
log in
sparkydude
Posted: Sun Aug 01, 2010 9:15 am |
| Senior Member |
Joined: Sat Aug 13, 2005 8:11 pm Posts: 2038 Location: Staffordshire Has thanked: 2 times Been thanked: 94 times
Morning,
Right looking at your pictures now in the light of day it is clear to me that your incoming main supply is in Lead covered cables as they go into the supply side of the suppliers 'head' this cable is their property and they should be summonsed to replace this outdated cable as soon as possible. If it goes as it looks the red from the old lead cable goes in one side of the taller grey box (mains fuse) and the other black core goes into the smaller grey square box (neutral link ) from each of the grey boxes a grey round cable goes to the meter and from there again two grey round cables go to the fusebox. Does your electricity supply come from overhead lines as that may explain why it comes from above the fuse box, or does your fusebox back onto a neighbours by any chance?
In order for us to advise you further on your next step and exactly what state your house wiring is in we need a picture of the inside of the fusebox. If and only if you feel safe to do this then please follow the below instructions.
1. Turn off the main switch on the left of your fuse box
2. unscrew the two screws on the front cover and lift off.
3.take pretty pictures and replace cover as step 2
4. turn power back on again .
Hope this helps
Nick
_________________ If it isnt broke dont bloody touch it until it bloody well is and if it is broke then make drawing of the connections before you remove the broken one and replace with a new one LoL
| Top |
register or
log in
dinx67
Posted: Sun Aug 01, 2010 11:16 am |
Morning Nick, thanks for your reply - it all makes perfect sense and is absolutely correct re: where all the wires go. We are a semi, so that the meter cupboard wall is the dividing wall between us and our neighbour. We are on a slight hill so their house is slightly higher than us, approx 18" or so. I am off to take more pretty pictures now, following your instructions very carefully!
| Top |
register or
log in
