Ultimate Handyman Home
flow and return
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
nalnacs
Junior Member
PostPosted: Fri Mar 21, 2008 7:44 pm    Post subject: flow and return Add User to Ignore List Reply with quote
Hi fella's
this may be a stupid question, but, how do i determine which is the flow and which is the return, i have two pipes coming from the ceiling that used to service a rad, and want to join into them, is it a floorboard up job?
Steve
Back to top
thescruff
PostPosted: Fri Mar 21, 2008 9:08 pm    Post subject: Add User to Ignore List Reply with quote
Short of following them you could turn the boiler on and see which gets hot first.
If you have drained the system, and cut the pipes, you could disconnect the zone valve and blow down the pipe, you would have to turn both valves off on all the rads, and it's not a 100%.
If you use by-directional valves its not that important
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
