Ultimate Handyman Home
flooring
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
crazienan
Junior Member
PostPosted: Thu Oct 09, 2008 3:18 pm    Post subject: flooring Add User to Ignore List Reply with quote
Hi there, I have a floor which is concrete base plus polystyrene and chipboard. My problem is the noise is driving me insane every floor in the flat creaks badly. I have thick carpet down with large thick rugs on top but no good. I have tried talc no good even sprayed kitchen floor with WD40. Help
Back to top
Tryanything
PostPosted: Thu Oct 09, 2008 8:42 pm    Post subject: Add User to Ignore List Reply with quote
Sounds like you have a chipboard floating floor
Posible reason for the creaking
The chipboard is rubbing against something like the door frames
Try and create a gap
They may have nailed the door frames to the floor and they have worked loose
Refix with screws
Look over the chipboard floor for any sign of nails sometimes they nailed
the chipboard to 50mm x 50mm battens with the polystyrene betwwen
Refix with screws, but put the screws right next to a nail so
as not to hit any pipes or cables
Hope thats of some help
Tony Tiger
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
