It is currently Thu Jan 17, 2019 3:42 am
 Post subject: Float switch
PostPosted: Wed Dec 27, 2017 9:48 pm
Not sure if this is the right place to post but I've come across this forum on Tapatalk while looking for electrical diy. I'm trying to construct a float switch to control a dc pump. I'm guessing this could be done via the float switch and a relay? The switch needs to turn off when the float is activated. Can this be done?would someone be able to draw up a circuit? And component list?
Many thanks
Sent from my BLN-L21 using Tapatalk
 Post subject: Re: Float switch
PostPosted: Wed Dec 27, 2017 10:05 pm
Has thanked: 65 times
Been thanked: 546 times
Most float switches are a simple weight and micro switch so when dangling from wire it is on and when fully floating off, it can be latching relays and two floats or a single float with the cable tethered often to the pump, in some cases the float only turns on the pump, low load when it draws air turns it off.
What decides it a lot of the time is what is being pumped, foam can upset probes and proximity detectors so no option but use floats, but swirling water can upset floats, so first what do you actually want to control, I have seen a plastic pipe with a float and magnet and reed switches, there are so many ways.
PostPosted: Wed Dec 27, 2017 10:12 pm
I've done more googling and I need a normally closed float switch.basically I want to control a pumps power to a tank to prevent overflowing just as a failsafe really...
PostPosted: Wed Dec 27, 2017 10:16 pm
Has thanked: 39 times
Been thanked: 1405 times
The big float switches are easy. (I cut one open to make sure the noise was a ball) Ball bearing, micro switch. It really is that simple. But the problem is making it 100% water tight. I wouldn't bother making one, I would buy one, smaller ones less than £5, but will need a relay, as they use a reed switch. Big ones with a ball bearing and micro switch £8
Did you know you can buy A.C. mains pumps with float switches already connected?
PostPosted: Wed Dec 27, 2017 10:19 pm
I made a video clip of one (different reason) for a forum member.
PostPosted: Wed Dec 27, 2017 10:20 pm
Yeah I am aware you can buy such things but I don't think it will suit my needs. Where would be the bedt place to collect a float switch? I have very limited space to work with.
PostPosted: Wed Dec 27, 2017 10:23 pm
ebay. (No really) Float switch.
PostPosted: Wed Dec 27, 2017 11:43 pm
Has thanked: 349 times
Been thanked: 1809 times
Get a float switch that suits. It will come with a switch (microswitch usually) attached and stamped on the microswitch, right beside the connecting terminals, will be three sets of letters:
c = common
n.o. = normally open
n.c = normally closed
Apply your power (live) to the 'c' terminal and take the power out from 'n.c' (for a normally-closed operation).
The neutral wire just goes to where the neutral always did.
Make sure the switch is rated to carry the current drawn by the load i.e. you can't use a switch rated at 2A to switch a load rated at 5A. Microswitches can come in a number of different ratings.
PostPosted: Fri Dec 29, 2017 10:51 am
How much DIY do you want to do? Image The three probe method is simple, no floats, also Image depends if DIY or ready built. Many other options sure you could use androno boards to do it today.
Here is another example it depends what you want to do.
PostPosted: Wed Jan 24, 2018 12:35 am
Has thanked: 147 times
Been thanked: 212 times
I made a simple one for our re-enactment society's Early Medieval Costal Trading Vessel (to small to be a Viking longship....) consisting of a ball cock from a toilet cistern, a microswitch and a 12 volt submersible pump for caravan water systems. The whole thing was run from a 12 volt car battery topped up by a solar panel mounted on the mast.
