It is currently Thu May 24, 2012 5:22 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
 Post subject: Flexi gas pipe
PostPosted: Thu Jan 19, 2012 9:43 am
Has thanked: 16 times
Been thanked: 5 times
Hi chaps.
Redoing a kitchen next week.
The hob is integrated gas, which I'm going to remove myself (someone has kindly fitted an isolator further up the pipe) but asides from that I'm not touching the gas pipes (advised to leave well alone!)
Going to get a gas fitter in to reroute the pipe for me as the hob will be moving a few feet.
Wondering if he can fit another isolator for me and a flexi pipe for me to connect up when I fit the hob, or will I have to have the hob in place for him already?
Cheers!
 Post subject: Re: Flexi gas pipe
PostPosted: Thu Jan 19, 2012 9:50 am
Has thanked: 17 times
Been thanked: 264 times
I can hear the Gas Safe guys sucking in their breath :lol: It should be a rigid fix I believe and no one can legally advise you (on here) in carrying out this work yourself. I would say get the gas fitter to do it to be on the safe side. :thumbright:
For this message the author dewaltdisney has received gratitude : DNS
PostPosted: Thu Jan 19, 2012 10:02 am
OAP
Has thanked: 187 times
Been thanked: 2113 times
Turning the valve off and just disconnecting it would make it ID, the regs say it must be capped.
Some Hobs can be connected with a cooker style hose, but not all, so you'll need to check the MI.
For this message the author thescruff has received gratitude : DNS
PostPosted: Thu Jan 19, 2012 10:25 am
Thanks for the tips guys.
Would not capping be a problem if the hob is only going to be removed for a couple of days, while the work is in progress?
I just don't want to have to go through the hassle of getting a gas fitter out to remove the hob, then back a few days later to re-fit it (more a time-table thing rather than cost, it's hard to estimate when I'll be ready)
PostPosted: Thu Jan 19, 2012 10:34 am
OAP
Not allowed to leave an open end, perhaps you could fit a compression cap as a temporary measure :wink:
PostPosted: Thu Jan 19, 2012 4:18 pm
Has thanked: 4 times
Been thanked: 39 times
You wouldn't want to leave it open anyway. How would you know if the isolation valve wasn't slightly leaking, or if it got knocked slightly open. You don't know how to do a gas tightness test to check; do you? How safe do you value your life and the life of your family :sad:
Your problem is now our problem
PostPosted: Thu Jan 19, 2012 4:31 pm
Has thanked: 166 times
Been thanked: 169 times
when we moved into our property we turned on the gas and heating and sat down in the kitchen had a few cigs and some beers... could smell gas so called the emergency line. turns out the previous owner removed the old cooker and had not capped off properly... could have killed us.
- Dave
http://www.pamperhouse.net
http://www.invertedcircle.co.uk
PostPosted: Thu Jan 19, 2012 4:43 pm
Has thanked: 9 times
Been thanked: 62 times
http://www.channel4.com/news/gas-explos ... s-injuries
this is what happens when thing arnt done properly
PostPosted: Thu Jan 19, 2012 4:45 pm
Has thanked: 57 times
Been thanked: 99 times
Worth noting there is no such thing as ''work in progress'' or '''temporary works'' were gas is concerned or the use of gas appliances,you have to follow the laws and regs all the time
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
