It is currently Thu Jun 21, 2018 1:32 am
PostPosted: Thu May 10, 2007 9:18 pm
Hi there- I wonder if someone can advise me how to fix a replacement toilet pan to the tiled floor.
The old pan was only a year old and cracked right through- it had a small amount of cement under it and silicone. Would cement have caused stress cracking?
I have removed the old pan, and the new one slots in fine.
When I screw up the back bolts to the cistern to get a tight fit, it lifts the pan about 1cm off the floor- so what should I fill the gap with? Or should I be lowering the cistern to meet the pan?
Should I bed the pan on mortar mix, or some sort of rubber gasket? Or is silicone enough, or maybe silicone on the mortar?
If on tiles, will cement be enough or do I need to screw the pan down as well?
Many thanks for all ideas.
 Post subject:
PostPosted: Thu May 10, 2007 10:06 pm
Has thanked: 548 times
Been thanked: 1641 times
If it is a close coupled unit I would say leave the cistern screws out. Get the pan level and stick it down with silicone. Shim the cistern to the wall to stop movement and silicon that as well.
 Post subject:
PostPosted: Fri May 11, 2007 8:36 am
Has thanked: 669 times
Been thanked: 1920 times
yes any pressure point will cause cracks
use brass stainless or bronze screws to secure pan to floor
and put vaseline[petrolium jelly]on the seat mounting thread before and after assembly
and as accidental dammage will possibly be coverd by your home insurance
 Post subject:
PostPosted: Fri May 11, 2007 11:21 am
Pro Handyman
Has thanked: 18 times
Been thanked: 27 times
Be Really Really careful screwing the pan down! :o
Jaeger.
