Ultimate Handyman Home
Fixing to underside of Galv Lintel
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
LyNx
Junior Member
PostPosted: Thu Jun 21, 2007 2:10 pm    Post subject: Fixing to underside of Galv Lintel Add User to Ignore List Reply with quote
I have a fairly newish house which has a set of 2100mm wide french doors. I want to remove these and fit a set of TOP HUNG folding/sliding doors. The way the system works is that the head of the frame has to be fitted to the structure above.
The galvanized lintel supports both the outer and inner skins and with a cavity of 70mm. Not sure on the exact type/reference etc.
Can i drill through the lintel into the blockwork above in anyway to fix the head of my frame? It asks for fixings of around 400mm centres around the middle of the opening so it's not asking for many holes.
If not, could the insulation within the cavity of the lintel be removed and a hardwood packer chemically fixed into the area work?
The doors (3 equal leafs) with be 120kgs total.
Andy
Back to top
sparkydude
Approved Electrician
PostPosted: Thu Jun 21, 2007 2:36 pm    Post subject: Add User to Ignore List Reply with quote
I cant see why not, when you say top hung do you mean the bottom of the doors run in a track on rollers or something like that,? In which case there is not a lot of weight on the lintel and you could drill and tap the steel lintel, or use self tapping screws. If it takes the full load of 120KG then i would look at some other way to fix the doors.Removing the insualtion part is not a good idea, but you could probably put a plate of steel over the gap and fix the track to that like before with bolts or self tappers.
Nick
Back to top
LyNx
Junior Member
PostPosted: Thu Jun 21, 2007 2:47 pm    Post subject: Add User to Ignore List Reply with quote
Nick. The doors are hanging from a 50x50 steel channel that fixes to the head of the frame.
Andy
Back to top
leebwk
PostPosted: Thu Jun 21, 2007 2:50 pm    Post subject: Add User to Ignore List Reply with quote
Hi LyNx,
I would just drill through the steel lintol with a slightly bigger hss bit then fix as usual using a masonry bit and normal fixings.
I say this as i have just fitted some sliding/folding door gear in exactly the same scenerio as yours.
Hope this helps
What was the best thing before sliced bread?
Back to top
LyNx
Junior Member
PostPosted: Fri Jun 22, 2007 7:48 am    Post subject: Add User to Ignore List Reply with quote
I have been hoping someones done this before, thanks.
What sort of weigth do these lintels support. I take it adding 120kgs is not going to make much difference? Confused
Back to top
marksson
PostPosted: Sat Jun 23, 2007 10:19 pm    Post subject: Add User to Ignore List Reply with quote
120kg wouldn't matter a jot.
Building Materials Sourcing
Softly, softly catchee monkey
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
