-> Building Forum |
| Author |
Message |
redrob Junior Member
Posted: Wed Mar 07, 2007 7:10 am Post subject: Fixing timber to top of steel beam |
Hi other than shot firing what is the best way to fix a 100x47 timber to the top of a steel beam?, can self tapping screws be used?
Thanks |
| Back to top |
panlid Senior Member
Posted: Wed Mar 07, 2007 8:07 am Post subject: |
| hi rob, what is the timber going to do? if it is not too heavy you could stick it on with gripfil or a polyurethane glue. |
| Back to top |
ultimatehandyman Site Admin
| Back to top |
Posted: Wed Mar 07, 2007 7:07 pm Post subject: |
| Hi the timber is to hang joist hangers from as spec.d on hanger site, they just dont specify how to fix the timber to the steelwork in the first place |
| Back to top |
Posted: Wed Mar 07, 2007 8:37 pm Post subject: |
| what exactly is the beam and how are the joists going to it? |
| Back to top |
Hitch Senior Member
Posted: Wed Mar 07, 2007 9:34 pm Post subject: |
Coach bolts, stagered along the flange is usually what we are asked to drill for. _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
jason123 Senior Member
Joined: 16 Dec 2006 Posts: 1239 Location: Stellaville
Posted: Fri Mar 09, 2007 8:20 pm Post subject: |
I thought to save height the joists went inside the RSJ at right angles. _________________ Stella Stella Stella oy oy oy |
| Back to top |
Posted: Tue Apr 03, 2007 7:34 am Post subject: |
The beam is a shallow PFC so cant cut joists into one side of it and otherside is a bit shallow so better to use c16 timber, even with this on top PFC wont be deeper than Joist.
Thanks |
| Back to top |
