It is currently Mon Aug 20, 2018 6:35 am
PostPosted: Fri Sep 29, 2017 5:08 pm
Has thanked: 7 times
Minor panic - having a worktop fitted over the weekend - have only just remembered to check the connection of the tap hose to the tap shanks - the fittings don't come together! Is it a nut that's used to join the two (not thinking this), or do i need different sized isolators on the end of the hoses? Will my tomorrow morning involve a rush trip to Screwfix? :roll:
Urgent help appreciated!
PostPosted: Fri Sep 29, 2017 5:31 pm
Has thanked: 26 times
Been thanked: 94 times
It's the other end that fits the tap the valve end fits onto the pipe with a compression fitting.
https://www.toolstation.com/shop/Plumbi ... tor/p30150
PostPosted: Fri Sep 29, 2017 5:47 pm
Ah. I think my plumber may have done that as I didn't have the tap at the time. Has meant I can still use the water.
Thanks Toolbox - I take it that hoses are universal in size?
PostPosted: Fri Sep 29, 2017 6:11 pm
Those look to be 1/2 inch common for sinks and basins, baths are 3/4inch only exceptions are monoblock taps that have smaller connections that are supplied with the tap assembly. So a 1/2 inch (15mm) will fit fine.
