Ultimate Handyman Home
Fixing plasterboard wall
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
danm123
Junior Member
PostPosted: Fri Mar 30, 2007 12:57 pm    Post subject: Fixing plasterboard wall Add User to Ignore List Reply with quote
Bit of a novice so please bear with me.
Removed some tiles from kitchen wall and have been left with two similar but slightly different problems
1) hole in plasterboard - understand best way to fill this is to get na off-cut in the cavity so it just covers from behind the hole and then re-fill...question is should i just use normal filler for this. Someone mentioned 'bonding' to me not sure what this is of if suitbale.
2) So areas, although not complete holes, are pretty badly busted. Not sure if ts best to cut out and go through steps for problem one, of there is a product that effectively re-plasters the plasterboard....(maybe this onding stuff Confused: )
cheers in advance for any help...
(where's the best place to go for an off cut of plaster board. ) Wink
Back to top
andy-p-
pro plasterer
PostPosted: Fri Mar 30, 2007 6:25 pm    Post subject: Add User to Ignore List Reply with quote
Hi danm123, you didnt say what you wanted to achive with the final outcome, at a guess skim the wall or tile?
1) put some p/b off cut behind hole and stick it with no nails or some multi, when stuck fill with bonding, scrim
2) next pva the hole and fill with bonding and scrim, when firm skim the wall or tile when dry Thumbright
Hope that helps
Back to top
PostPosted: Fri Mar 30, 2007 6:34 pm    Post subject: Add User to Ignore List Reply with quote
Bonding is undercoat plaster and is mor economical and easier to use on large areas than filler.
These pages should help Wink
http://www.ultimatehandyman.co.uk/PLAST_REPAIRING_HOLES_IN_PLASTERBOARD.htm
http://www.ultimatehandyman.co.uk/PLASTERING_BACKING_PLASTER.htm
If you use bonding you need to make sure it is shy of the surface by a couple of mm so that you can finish off with finishing plaster.
DIY | DIY Video
Back to top
andy-p-
pro plasterer
PostPosted: Fri Mar 30, 2007 7:13 pm    Post subject: Add User to Ignore List Reply with quote
sorry i assumed he wanted thr whole wall skimmed after filling Smile
Back to top
PostPosted: Fri Mar 30, 2007 7:25 pm    Post subject: Add User to Ignore List Reply with quote
That would probably be the best option as it's much easier then trying to patch Wink
(not sure about where to get off cuts from, unless there are any builders working in your area. You can get a small sheet from the sheds for a couple of quid!)
DIY | DIY Video
Back to top
danm123
Junior Member
PostPosted: Fri Mar 30, 2007 8:38 pm    Post subject: Add User to Ignore List Reply with quote
cheers guys
1) Understood
2) so if i understand right, i go over all the busted area with PVA (this is just the white glue right?and not something else with the same anachronym)...then when dry use the same bonding that i used to fix hole 1)
both areas are going to be tiled so finish not important
Back to top
andy-p-
pro plasterer
PostPosted: Fri Mar 30, 2007 9:23 pm    Post subject: Add User to Ignore List Reply with quote
Yep pva it, fill it, tile it, then pub lol
Back to top
danm123
Junior Member
PostPosted: Sat Mar 31, 2007 7:22 am    Post subject: Add User to Ignore List Reply with quote
thanks for your help guys
just one slight change
pva it, fill it, call a tiler Laughing , pup Razz
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
