Ultimate Handyman Home
Fixing laith and plaster
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
steves plastering
PostPosted: Mon Jul 02, 2007 8:10 pm    Post subject: Fixing laith and plaster Add User to Ignore List Reply with quote
I have to fix a loose patch (about 3sq/foot) of plaster which has come away from the laith before skimming the whole wall.
I plan to cut away a nice square to expose timber fixings and screw board on with a few dabs od dry wall on the back to increase stability etc...
However the plaster is really thick about 16 - 17mm and one board is too shallow and two boards too thick.
Can i fix one board and then use bonding coat to build it up on the plaster board ( i'm sure someone said you should never put bonding coat onto board)
or
Can i use dollops of dry wall adhesive on the timber and the old laith to stick board on at the right depth and wait an hour till this starts to go off and then screw through it onto the timber to give it that extra hold?
Any other options guys?????
All suggesstions welcome apart from tearing the whole wall down, i really can't be arsed with that as it is all in good knick apart from this patch.
Thanks Steve.
Back to top
andy-p-
pro plasterer
PostPosted: Mon Jul 02, 2007 8:25 pm    Post subject: Add User to Ignore List Reply with quote
i would go with the bonding option, done it loads if time like that. dont forget to scrim it before you skim
Back to top
moon133
PostPosted: Tue Jul 03, 2007 11:34 am    Post subject: Add User to Ignore List Reply with quote
I had this problem.
You just attach battens to the sides of the timber uprights and bring them out a few millimeters to put the plaster board at the right level.
If the original plaster is 17mm and your using 12mm Plaster board, bring the batten forward 5mm so the board is flush with the surface to be skimmed. It doesn't have to be perfect, so long as it doesn't come out too far.
Remember to put nogins at the top and bottom of the hole under the plaster board. It'll help strenthen it.
Mummy said I was special!
Back to top
steves plastering
PostPosted: Wed Jul 04, 2007 12:17 pm    Post subject: Add User to Ignore List Reply with quote
i'll give the dry wall a go in big dollops, seem like the better option..
out of interest, can you use Thistle bonding coat onto boards???
i was sure someone told me that you can't.
Thanks Andy-p
Steve
Back to top
steves plastering
PostPosted: Wed Jul 04, 2007 2:53 pm    Post subject: Add User to Ignore List Reply with quote
ahh, moon
sorry computer died and for some reason wouldn't show your post till just now.
Good plan,, i'll take another look and see if the size of the hole is worth doing it your way (timber and noggins etc) which sounds equally good.
Any ideas on the bonding coat on boards question???
Steve
Back to top
andy-p-
pro plasterer
PostPosted: Wed Jul 04, 2007 7:11 pm    Post subject: Add User to Ignore List Reply with quote
Yes mate course you can use bonding on plasterboard, its for low suction backgrounds Wink
Back to top
andy-p-
pro plasterer
PostPosted: Wed Jul 04, 2007 7:14 pm    Post subject: Add User to Ignore List Reply with quote
Check the link steve if you dont believe me lol
http://www.british-gypsum.bpb.co.uk/products/thistle_plaster_products/thistle_undercoat_plasters/thistle_bonding_coat.aspx
Back to top
steves plastering
PostPosted: Wed Jul 04, 2007 9:48 pm    Post subject: Add User to Ignore List Reply with quote
excellent, thanks. i must have gotten the wrong end of the stick or more likely listened to half of somones conversation.
Cheers Steve Thumbright
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
