It is currently Wed Dec 19, 2018 2:06 am
PostPosted: Mon Jun 08, 2015 9:07 pm
Been thanked: 2 times
I have recently replaced the gatepost and gate etc.
75x75 post next to a wall
I was recommended to use these
Thunderbolt Hex Head Passivated Zinc/Yellow 10mm (M10) x 150mm
http://www.alsfordtimber.com/tools-fixi ... -8372.html
and to use a 10mm drill
anyway, they all bolted back into the wall OK
and I had a bigger hole in the timber so the timber part was about 50mm ish
height of post about 2.1m
4 bolts used
use something like this
http://www.screwfix.com/p/fischer-fsa-s ... f-20/66010
Or some form of plug around the existing bolt, paper
I have a wall now with 4 x 10mm holes - maybe slightly bigger
Post 75x75 - drilled 11/12mm for the bolt to go through
Sunk into the post by about 25/30mm
The gate 1900mm high by 780mm wide is hanging off this post
thanks in advance for any suggestions
PostPosted: Mon Jun 08, 2015 9:34 pm
Has thanked: 102 times
Been thanked: 353 times
Resin anchors.
Wins where everything else fails generally....
PostPosted: Mon Jun 08, 2015 11:49 pm
Has thanked: 163 times
Been thanked: 281 times
I agree with Hitch - no other sensible option.
Take the gate off, remove the post completely, knock the bolts back level with the wood, squirt the resin anchor into the holes - don't use too much, there isn't a lot of room in that hole - and make sure you read the instructions on the resin anchor tube - don't hang about, resin anchor can go off quite quickly, position the post back in place and whack the bolts back in with a hammer, using a drift if your hammer head is too big to get them fully home. Have a cup of tea, hang the gate back.
Good luck.
PostPosted: Tue Jun 09, 2015 7:49 am
ok that sounds good - I will have to go have a look at the resin options in the local DIY stores
unless you have some recommendations
PostPosted: Tue Jun 09, 2015 11:10 am
Has thanked: 147 times
Been thanked: 212 times
The likes of Screwfix etc. will be much cheaper(half the price!) than most of the DIY stores. Ie. Screwfix resin tube that fits in a standard skeleton gun about £ , Wickes about £11(and that was on special!!)
PostPosted: Tue Jun 09, 2015 4:15 pm
Ok,
so just something like this
http://www.screwfix.com/p/no-nonsense-p ... 75ml/53359
PostPosted: Tue Jun 09, 2015 9:56 pm
How to guide-
http://www.ultimatehandyman.co.uk/how-t ... in-fixings
PostPosted: Tue Jun 09, 2015 10:19 pm
Thanks for the guide
PostPosted: Fri Jun 12, 2015 5:40 pm
i have picked up the studs 12mm as shown on the video/instructions and resin - so will do this over the weekend and let you know
thanks for the advice
PostPosted: Sun Jun 14, 2015 6:57 pm
installed this morning using the resin, worked fantastic - gate put backup tonight and its now all up again with a very solid post against the wall
thanks for all your help
For this message the author etaf has received gratitude : Hitch
